Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-09-2009, 08:42 PM
Coolster is on a distinguished road
Question New to bobcad v22 help opening file?
Hey guys I am new to bobcad and cam programming I have solidworks 2008 and have saved my part as an XT file and every time I open it in bobcad v22 I get an error and bobcad shuts down? I do have the latest build of v22 what do I do?
Old 02-09-2009, 09:03 PM
BurrMan is on a distinguished road
".sldprt" is BobCads Solidworks importer. Not familiar with solidworks so dont know what an XT file is. Maybe someone else?
Bueller.....Bueller?
Old 02-09-2009, 09:46 PM
Question
Ok I just exported it as an iges file and was able to open it up now having trouble with tool paths alot of inside pockest with holes 4th axis out or round stock but I am just indexing this part my problem is getting a tool path that will work it needs to go from the end of the part and finish this part in 1/2" at a time in full because it sticks out of the 4th 5 inches I am useing a 1/2" cutter the stock is 2" round the part is 3/4" tall but the first milling is 1.25 from top of stock it is an offset part kind of like a z____ shape. When I run the tool path the entire system shuts down?
Old 02-09-2009, 10:10 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
http://www.sharpened.net/helpcenter/extensions.php
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 02-09-2009, 11:18 PM
moldmker is on a distinguished road
I have the best luck with .sat files from SW into v22. Large files load quickly.
Don't know about v23.
Good luck,
moldmker
Old 02-10-2009, 03:14 AM
Good luck,
moldmker
Doesnt V22 import solidworks files???
For Coolster, can you post a file to help explain? It's kindof hard from a forum description.
Burr
Old 02-10-2009, 07:04 AM
Burr
Had no problem opening an iges file but everyother time I try a new tool path it shuts down? The entire software shuts down? I am calling bobcad today I have to get this working it is going to put me in a crunch if i dont get this part running within a few days. I will try to post the file tionight.
Old 02-10-2009, 08:02 AM
Doesnt V22 import solidworks files???.....
Yes, but if the model is complicated it takes a long time to load. Some I've aborted after 30 mins.
Convert it to .sat and it loads in 5 secs.
(my observation on my system, never confirmed on other systems)
Also, SW has different Configurations that can be applied to it's model. This is an engineering tool that allows a model to be configured in different states, such as: with or without holes (or just a certain hole), castings "as cast" and "as machined", sheetmetal parts "as bent" and "flat pattern", etc.
When you import a .sldprt into BC there's no opportunity to select which Configuration you want, so you get them all combined in one model.
Save it as a dumb solid (.sat, .igs, .stp) and it saves as the current config.
I got burnt once by a hole pattern mix-up, I don't chance it anymore.
If you're getting SW models from customers without prints, you may want to get SW's free viewer called eDrawings so you can verify model configurations.
moldmker
Old 02-10-2009, 11:05 AM
Question
moldmker
I own solidworks 2008 my work keeps me on it. I have saved it as an ides file and bobcad opened it up fine it looked fine I did some tool paths but 90% of the time bobcad will shut down or freeze with no responce when I try to make a tool path?
Old 02-10-2009, 02:34 PM
Can you post a sample .igs file for us to look at?
Make sure it's one that gives your system trouble, then we can isolate whether it's the file or your system.
I use SW 2007 into v22 with minimal problems.
moldmker
  #11   Ban this user!
Old 02-10-2009, 02:35 PM
OIC,
Thanks for taking the time to edu me!
Burr
Would like to see if the file crashes my computer.
  #12   Ban this user!
Old 02-10-2009, 05:26 PM
Question
OIC,
Burr
The file is to big to upload. 1.45 MB (1,530,940 bytes) The computer is not crashing the software is I am on a computer that can handle it with not even a thought.
opening a mastercam x file on v9 drewmeister Mastercam 3 12-15-2008 06:54 PM
Need Help!- Opening CDR file extension. terry32506 General CAM Discussion 5 03-02-2008 11:53 AM
Opening ProE (prt) File allennella Mastercam 5 10-10-2007 09:19 PM
Opening dxf in bobcad bhkelly BobCad-Cam 8 02-22-2007 08:09 AM
Opening Mastercam In Bobcad lakeside BobCad-Cam 10 05-02-2006 11:38 AM
