Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-08-2009, 04:16 PM
Ranscon is on a distinguished road
Which computer is better?
Hello all,
I am currently using Bobcad v23 /Bobart v23. I have just purchased 2 laptops. One for me and one for the wife. I am trying to decide which one I want. This is not the shop computer that runs my machine, just a laptop for me to design things on when I,m not in the shop.
Laptop #1 is an Acer 5515 with an AMD single core processor(1.6 ghz)with 3gb of ram,
Laptop #2 is a Compaq cq60-214dx with an intel dual core processor (2.16 ghz) with 2 gb of ram
Both have graphics cards that support open GL.
Which would be better for this cad software?
Personally, from past experience, I prefer AMD over Intel, (intel processors should come with a helmet due to the frequent crashes) but will the extra gig of ram make up for the slower single core processor, or does the single core to dual core difference not matter in this case? I don't know if Bobcad is a multithreaded application or not.
Thanks very much for any advice, Jeff
Old 02-08-2009, 04:33 PM
*Registered*
HMB3000 is on a distinguished road
Keep the one with the dual core...I have done a few 3d files and have seen it spike at 75% on my dual core for CPU Useage
Old 02-08-2009, 06:13 PM
BurrMan is on a distinguished road
You did state that you prefer the AMD chips, and the graphics card can make more of a difference than "Supports OpenGL".
Put the specs of the two cards up also. There may be enough of a difference that you'de give your wife the cpu's to get the card, (Your definitely giving up processing power) but may settle for better display power to work off your AMD you prefer.
I personally would go with the dual core because you can always buy a new card. (I guess that depends on the laptop) but then I'm an Intel guy. Trying to figure what I would do if I had to pick a single Intel cpu vs. the amd dual processor. A tough sell for me because I have your same aversion to the amd's!
The card may make your decision.
Old 02-08-2009, 06:31 PM
The AMD's card is the ati radeon 1200x. The intel just has the intel graphics accelerator. I don't know much about either but the Bobcad support guy just told me to make sure it supports open GL.
Any preference here?
I think I'm leaning towards the intel.
Does a 2.16ghz dual core mean it has 2 chips running at 1.08 each for a total of 2.16 or do they each run at 2.16 for a total of 4.32?
Thanks again, Jeff
Old 02-09-2009, 04:39 AM
Thanks again, Jeff
Its the later. And theres nothing so special of the amd card that would overide the processor benefit!
except the wifes appreciation!!!
Intel choice would benefit bobcad more.
PS.
I appreciate being able to participate!
Burr
Old 02-09-2009, 05:38 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Always Intel vs AMD
Just keep in mind that you can have the fastest Processor but if the Front Side Bus is too low in MHz it will be slow.
Look for something with 800MHz to 1600MHz
As far as RAM go with the Max 4 GB for a 32 bit OS
6 mb Level 2 Cache
These ratings below are for a Dell Precision M4400 and Validated by CPUID.
This thing SCREEMS through tough projects.
ID:	75294   Click image for larger version
ID:	75296   Click image for larger version
ID:	75300   Click image for larger version
ID:	75302   Click image for larger version
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 02-09-2009, 06:00 AM
tobyaxis's Avatar
Moderator
Thanks again, Jeff
Two Cores running 2.16 Ghz each.
Also keep in mind that CAD/CAM software will only use 1 core, but that also means there is more room for processing.
Dual Core means Two Cores in One Stamp like one on top of another.
Think about the Intel Xeon Quad Core, 4 cores in one stamp.
Toby D.
Schwarzwald
Old 02-09-2009, 06:39 AM
*Registered*
it will use both cores for process that the big advanged....Processing time for a complex 3d path will be greatly reduced...
Old 02-09-2009, 06:50 AM
tobyaxis's Avatar
Moderator
Here is a little insight on Milti-Core Processors. This is the present BENCH TEST for X3
Emastercam Forum
http://www.emastercam.com/ubb/ultima...;t=026247;p=21
bogusmill
Senior Member
Member # 896
posted 01-28-2009 12:00 PM01-28-2009 12:00 PM In X3 only one core is working but in task manager under the performance tab, in the CPU usage all cores appear that they are being used when in reality it's the cache that is shared showing up on the graph. On a quad core typically one core shows very high use, 2 show medium use and one low use. The high use is the tool path, medium is shared cache and low is video card use. If you move the part you will see the low use cpu get real high use.
National Institute for
Aviation Research @
Wichita State University
MCX3 MU1/Catia R18 x64
Vista Ultimate SP1 x64
Asus Rampage Formula
Xeon X3550 Quad @ 3.8Ghz
8Gb G. Skill PC8500 RAM
eVga GTX 260
Raptor 150GB 10K RPM HD
2 Dell 24" widescreens.
Toby D.
Schwarzwald
Old 02-09-2009, 03:37 PM
Originally Posted by tobyaxis View Post
CPUID
Hi Toby,
That looks like a handy utility. Am I right it does not yet support Xeon Quad Cores?
Bookmarked for use.
Burr
Computer ? twocik Tormach PCNC 13 01-28-2009 10:52 AM
What is the difference between an industrial computer and a normal computer? Apples Controller & Computer Solutions 9 09-18-2008 05:27 PM
using a computer for a DRO bmachinist Calibration & Measurement 1 02-14-2008 10:58 PM
New Computer bill south Computers and Networking 5 08-05-2005 12:26 PM
fast computer as server, slow computer as terminal replicapro Computers and Networking 1 07-01-2004 03:05 PM
