Results 1 to 2 of 2
Thread: Eliminating the automatic "G91" in Mach 3 Post Processor
    Mar 2004
    Question Eliminating the automatic "G91" in Mach 3 Post Processor
    How do I open the Mach3Mill post processor so I can remove the automatic G91 that's added at the end of the toolpath? I forgot to take it off the end of a post and the next operation resulted in the incremental mode driving the spindle DEEP into the workpiece. I NEVER use uncremental mode so I want to set the post processor so it doesn't insert it at the end of the toolpath.
    Last edited by m1911bldr; 01-14-2009 at 05:08 AM. Reason: Forgot to say I have V22!
    Registered The Engine Guy's Avatar
    Jun 2008
    UK
    Quote Originally Posted by m1911bldr View Post
    Go to "My Computer" and type in this path
    C:\Program Files\BobCAD-CAM\BobCAD-CAM V22
    Once there look for the Icon that has the name "MillEditPost", double click on it and the Mill Post Editor will open, from the drop down list select your post and from the "Tree" on the left select the part of a program you want to modify and edit away as much as you like.
    It is always a good idea to go to here first:-
    C:\Program Files\BobCAD-CAM\BobCAD-CAM V22\Posts\Mill
    Find your Post and save a copy of it out to a folder somewhere on your PC so that if you make a mess of the editing you will still have the original Post saved!!
    Good luck!
    Regards
    Rob
  1. "Mach Convention", (South East)...any interest????
    By PoppaBear10 in forum Trade Shows and Events
    Last Post: 03-26-2008, 08:44 PM
  2. "No g100's found in system" Mach 3
    By MillingMaiden in forum Mach Mill
    Last Post: 08-06-2007, 11:35 PM
  3. Can Mach-like software run "hobby servo"?
    By dondeaida in forum RC Robotics and Autonomous Robots
    Last Post: 07-23-2007, 10:55 AM
  4. Replies: 6
    Last Post: 07-06-2007, 08:43 PM
