Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-10-2009, 11:33 AM
hall6ppc is on a distinguished road
radius 3d tool path in v22 ?
ID:	73278Hello, I have been having a problem with my 3d tool paths in v22. It seems when I try to generate a tool path on a part that has a fillet the tool path does not seem to follow the contour correctly. I have attached a picture of a simple part that has a .1 radius . The tool being used is a .250 ball end mill from tool tip. I have even generated the tool path with a small .001 step over just to see if it would help follow the contour better. However it looks like to me it is still wrong. What could I be missing?
PS I have tried all the 3d tool paths in v22 and they seem to do the same thing.
Thanks for any help!!!
Old 01-10-2009, 11:55 AM
*Registered*
HMB3000 is on a distinguished road
Originally Posted by hall6ppc View Post
...a simple part that has a .1 radius . The tool being used is a .250 ball end mill from tool tip.... However it looks like to me it is still wrong. What could I be missing?
What you could be missing is that you can't cut a .1 inside corner raduis using a tool that has a .125 side raduis...Try either a smaller tool or a bigger raduis
Old 01-10-2009, 12:36 PM
Originally Posted by HMB3000 View Post
What you could be missing is that you can't cut a .1 inside corner radius using a tool that has a .125 side radius...Try either a smaller tool or a bigger raduis
HMB3000 this is a outside radius on a corner ( convex) . I tried it again with a smaller tool (.0625 ball end mill) .010 step over , from tool tip. Looks like the exact same tool path. Also with .062 ball end mill it sure goes off the edge alot ( I have .0000 roll over )
Also I have drawn the exact same part in Mastercam X and get the correct tool path . Notice the diffrence of how the tool follows the radius
[ Click image for larger version
Name:	master cam radius.jpg
Any ideas thanks for the help all!!!
Old 01-10-2009, 01:53 PM
*Registered*
sorry about that it is hard to tell from a jpeg...can you post the file? It maybe the build your on...Have you updated lately?
Old 01-10-2009, 03:04 PM
I am running 1137 build on V22. I ran a test part with program and it looks just like the tool path that was posted. I also ran some .500 convex radius and they to are not right . I tried to attach the bbcd file but couldn't figure out how to do that.
This is a 1.0 cylinder , just trying to see if I could get a .500 radius tool path. Not sure if you can see but I put measurement points to show where the centerline of tool should be ( I think), notice how far out the tool path is. . Tool is a .250ball end mill.
Old 01-10-2009, 07:02 PM
mmc005 is on a distinguished road
If you want to post your file, try to zip it and then attach it to your post.
Are you saying that the center of the tool is further than .125 from the outer edge of the cylinder? Can you post the code for that cylinder?
Dave
Old 01-10-2009, 08:47 PM
quote=mmc005;550015]If you want to post your file, try to zip it and then attach it to your post.
Dave[/quote]
Yes it seems the tool center is .709 from center when Z is at -.5 . I drew the same part in Mastercam X and code look like when Z is at -5 , X will be at .615 . Which would seem to me to be correct.
I will post the mastercam code .
ID:	73302   Click image for larger version
Old 01-11-2009, 07:48 AM
Dave
I will post the mastercam code .[/QUOTE]
This is the Mastercam X file of the same part . It looks correct to me. I sure would like to figure out what is wrong with the Bobcad . I can't use it it like this . Any Ideas ???
ID:	73345   Click image for larger version
Old 01-11-2009, 08:40 AM
moldmker is on a distinguished road
For all of v22's misgivings, the 3D stuff does work pretty good for me.
I do inspect my parts with a toolmaker's scope for verification.
I recreated your 1.0" cylinder and it's correct on my system.(see pic)
I see your Z coords reach 0 , so your XYZ Allowance is probably 0.
There must be something going on with your tools.
Since .5 dia is the default tool size for the 3D ops, I'm betting that somehow your tool info is not being applied to the 3d op. (tool pic attached, for ref. only)
Does the error occur with other size tools?
Does the error occur with a manual tool vs. a system tool?
When you use the same tool on a simple 2D Profile operation, does it show the same offset error?
moldmker
Old 01-11-2009, 04:47 PM
moldmker
Attachment 73349
Attachment 73350
moldmker- I tried just entering in tool dia in "system tool" instead of using manual tool and then selecting my tool from library library. I got the correct tool path then !!!! Wonder what the problem could be with my tools in the library ?
I also tried the part in the DEMO v23 and it does the exactly same thing. Guess I will call tech support this week to see whats up.
Thanks fo all the help
  #11   Ban this user!
Old 01-12-2009, 12:48 PM
tjones's Avatar
tjones is on a distinguished road
I believe the manual tool selection issue has been reported in V23. I also had the problem when using manual tools in 3D operations. It appears as though the software forgets to change tools.
In V23 do a tool verify before posting and see if it is incorrect. I found this when doing multiple Z level roughing where each had a manual tool selection with different tools.
Need Help!- can't get the tool path right msn_jrd Mastercam 3 07-21-2008 10:43 AM
3-D TOOL PATH reedmiles BobCad-Cam 15 02-02-2008 07:08 PM
Tool Path cijunet Mastercam 9 11-26-2007 09:17 AM
Tool approach Tool Path Kiwi BobCad-Cam 28 07-05-2007 02:35 AM
Tool Path WOODKNACK TurboCAD/CAM 4 06-27-2003 07:27 AM
