Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-07-2009, 08:42 PM
Claude Boudreau is on a distinguished road
Question autocad with bob-cad?
I am still with ver.21, one thing I would like to have is what is called handles or grip , when you select your drawing or an entity you can click those and stretch it the way you want. I can get my hand on autocad 2008 , do you know if it is compatible with bob-cad, and will I be able to stretch my drawing in the Z axis?
In other words, can drawings done with bob-cad, be modified in autocad, and then use in bob-cad?
Old 01-07-2009, 09:49 PM
GeneK is on a distinguished road
Claude, I have ver 20 and 22. In 20 I can go back and forth between Acad and BobCad as long as I use the DXF files. When I tried to use BobCad DWG files in Acad I had problems. As always as they say 'your mileage may vary'.
GeneK
Old 01-08-2009, 05:38 AM
tjones's Avatar
tjones is on a distinguished road
DXF is the best way to exchange drawings. All versions of Autocad (about V13 to current) I have used including the latest can stretch single or multiple entities.
Old 01-09-2009, 04:18 PM
mc_n_g is on a distinguished road
The DWG formats between the two are not the same.
DXF level for the current Bobcad version is not known to me. At one point in time they could only support up to version 12 or 13 of DXF. What does this mean? You can transfer lines, cirlces, points, polygons fine but as you get into 3D features, meshes, and edges you have problems.
Old 01-09-2009, 05:35 PM
Cool autocad bobcad 3d
Some programs tells you can import dxf files but the 3d component is all over the place and the drawing look like a poor photocopy...I need to modify 3d drawing in autocad and use them in bob-cad for machining.
Old 01-12-2009, 12:52 PM
tjones's Avatar
If you are doing solids then export/import as a solid. Try stp or igs files. 3D dxf is a problem for many other CAD programs. I think they like to mix it up every year to keep others from using it.
Newbie- sw <=> autocad apexi Solidworks 7 05-01-2008 05:14 PM
CAM in autocad Alex S.A General CAM Discussion 7 04-21-2007 10:47 PM
autocad to pdf andyinmo Autodesk Software (Autocad, Inventor etc) 15 07-18-2006 06:58 AM
AutoCAD MBG Autodesk Software (Autocad, Inventor etc) 7 06-04-2006 07:46 PM
Autocad LT verse AutoCad LT CNCadmin Autodesk Software (Autocad, Inventor etc) 2 02-03-2004 07:28 AM
