Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 12-27-2008, 09:43 PM
Stampede is on a distinguished road
Is there a way to have BC print out a Blue Print of a drawling?
With a border, company info,ect. If so, how?
Thanks.
Old 12-28-2008, 05:08 AM
The Engine Guy's Avatar
The Engine Guy is on a distinguished road
Thanks.
Not that I know of, best I reckon you could do would be to draw a "blank" one with boxes you can put text into and use it as a base template for your drawings.
Or, you could go here http://www.alibre.com/support/downloads.aspx and download the FREE "Express" version which has that facility built in and will Import your BobCAD file as a DXF, you can also download free "PDF Creator" which will print out the drawing as a PDF file in various sizes such as A3, A4 etc, etc.
See screen grab below.
Regards
Rob
Name:	Alibre Drawing View.jpg‎
Old 12-29-2008, 05:26 PM
Thanks.
Stampede
Here is what you can do with a little work in BobCAD, I cheated and just imported a .dxf just for speed and demo.
Bit "rough and ready" but should be good enoughto get the idea across I hope!!
You can simply draw up something like the one I`ve done in the attached files and then save it out as anything, I chose "BobCAD Blank" for the demo. Then you can just open it do your drawing and save first as a .bbcd under a different name so you could re-open in BobCAD if any alterations were needed. Then if you have downloaded the PDFCreator you only need to click File > Print > and select "PDFCreator" as the printer and it will create a .pdf file that you can print off to whatever size your printer will handle.
I`ve attached the .bbcd file and the .pdf for you.
Hope the idea works for you, maybe BobCAD will pick up this ball and run with it???
Regards
Rob
Old 01-05-2009, 07:36 AM
cncgman's Avatar
cncgman is on a distinguished road
Smile wOw
Good friggin' job, that looks ggrrrrrrrrrreat !!!
How to print ion a 3d surface whiteriver Printing, Scanners, Vinyl cutting and Plotters 3 01-20-2010 03:39 PM
cant print? erase42 BobCad-Cam 13 11-30-2009 08:05 AM
Need Help!- No Print or Drawing operations1 DynaTorch 0 10-01-2008 06:57 PM
0.8 um Symbol on print ? RMARCH General Metalwork Discussion 4 11-30-2007 09:55 PM
Blue print creation mroy0404 Mastercam 6 11-21-2006 04:38 PM
