12-10-2008, 03:38 PM
Have V22 but need help with V19 ?? | | I'm trying to get up on V22 but still have to use 19 and I'm having the following problem.
I open a dxf drawing. I am building a large program feature by feature. I have 2 milling operations don, and saved as a tap file. I open the Cam side, load this tap file, place the cursor where I want the code, and do a G83 pull down.
When I click G83 it bypasses the G83.bas file and does not show the scripted box asking the pecking parameters, just puts down the X and Y moves with a G83 and a G80.
If I start with a blank Cam window it works just fine. Asks me the R, F, Q, as it should.
Is this fixable or do I have to copy and paste to do this?
Thanks,
Nelson
__________________ i build the braces that keep american teeth straight......tick tick tick |
