Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 12-07-2008, 04:19 PM
seanreit is on a distinguished road
in bc 21 how to stop post from using g2 / g3 EVER
i don' t want the post processor to be able to make a g2 or g3 move ever! Is there a way to do this?
Old 12-07-2008, 07:29 PM
*Registered*
HMB3000 is on a distinguished road
Your post is fine if you don't what a G2 or G3 just don't try and cut any type of a raduis....Why don't you want a G2 or G3?
Old 12-07-2008, 07:32 PM
Nevermind, it's because of crop circles, I found I could edit the post processor to change every g2 or g3 move into a g1 move, problem solved.
I read every thread here and at mach about crop circles, none of the solutions worked, this one does. I use 22 bobcad for my mill, but still use 21 for my lathe.
Old 12-12-2008, 11:05 AM
KIMFAB's Avatar
KIMFAB is on a distinguished road
I'm new at this (just opened my v21 after sitting on the shelf for 2 years) but according to the book there is a general accuracy setting that if set tighter than your machine can handle will cause the machine to do crop circles.
I used to be appalled, now I'm just amused.
Old 01-08-2009, 03:14 PM
Sowen is on a distinguished road
V21 WITH NO G2 or G3
Before generatring the code click on 3d>More>Interpolate use region for the selection and be carfull with your accuracy,this will convert arcs to lines.
New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop GreenLead LinuxCNC (formerly EMC2) 12 08-03-2010 12:05 PM
Another E-stop, Home and limit post binary_d Mach Mill 2 10-05-2005 06:19 PM
