Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 12-05-2008, 10:09 PM
Claude Boudreau is on a distinguished road
Unhappy using the drag command
Can you draw an entity in 3D and copy it using the (change /translate/drag) command without loosing the Z level ?
Or do you have to copy using the increment command? Still using ver.21
Old 12-05-2008, 11:53 PM
DJPLAST is on a distinguished road
I just drug a solid cube while I was in the "TOP" view and moved it to the top right quadrant. The "Z" position did not change but the x and y did.
I don't know if this answered your question.
Old 12-06-2008, 05:27 PM
Unhappy problem with drag command
I have not use it with solid , but let`s take a simple arc starting at X0,Y0,Z0, then X1,Y0, Z-0.5, and ending at X2, Y0, Z0. try moving it using drag , then verify,or look at the front view, it does not keep its z level with me...
Old 12-07-2008, 12:14 AM
You a correct, it did the same thing for me. I created the arc in the "front" view with the points given. Then I selected the arc in the "TOP" view and moved it to a new x y location, and when returning to the "front" view, it has moved up in the "Z" axis. OK now what caused this? hmmmm? I tried selecting while in the top view at different locations on the arc (near the point on the left, near the lowest point, close to the center point, each yeilding the same result......) Any body else got a clue? Mine resulted in moving about 50% up in the front view.
Old 12-07-2008, 03:12 PM
Unhappy What a drag!
Anyone else with a solution to this ? It seem to actually move the arc midway on the z axis.Check with verify...
Drag Engraver Regnar Benchtop Machines 8 04-22-2011 01:16 AM
How to homebrew a drag knife for vinyl cutting abasir Printing, Scanners, Vinyl cutting and Plotters 11 11-01-2010 08:58 PM
M01 command slideleft Haas Mills 4 11-20-2008 03:01 PM
what is the same command? hop G-Code Programing 0 06-20-2006 05:24 AM
Home Built Router/Drag Diamond Engraver DaSigntist DIY-CNC Router Table Machines 49 01-24-2005 01:02 AM
