Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 11-29-2008, 04:03 PM
hall6ppc is on a distinguished road
Z level roughing V22 ?
What is the trick to getting the Z level roughing tool path in V22 to start out cutting material on the the first pass ( by level) . It seems like alot of my attempted tool paths all start out cutting air above the part . I have all parts set with top at Z .0000 .
Thanks for the help!!!!!!!!!!!!!!!!!!!!
Old 12-04-2008, 08:53 AM
rwestbr is on a distinguished road
If I'm not mistaken...It will cut air when you specify a cutting allowance in the cutting properties....
ROB
Old 12-19-2008, 03:35 PM
orizaba is on a distinguished road
Bobcad will look at the bottom of the part, raise up the amount specified in the "stock remaining" box, then each z level will be above that point by the amount specified in the "depth of cut" in the edit tool path section. So the top layer will be above the stock by less than the depth of cut. I always just go in and delete all the z+ layers.
Hope this helps
Matt
Old 12-19-2008, 08:04 PM
Hope this helps
Matt
Can you explain how you delete " all the z + layers " Are you talking about the tool paths above part zero ??
Old 12-22-2008, 09:50 AM
Sure
In the post editor (predator) , just highlight the code after the Z+ lines and hit delete. Be careful to go back look at the code to make sure you done crash a tool. You may want to add a Rapid Z.1 (assuming top of part is Z0.0)between the the blocks you edit.
Tips on Roughing , Please. lostkoss General Metalwork Discussion 19 10-09-2008 04:36 PM
Roughing Steel Alex Westling General Metalwork Discussion 7 06-12-2008 10:08 AM
roughing cycle on ot-a iancally Fanuc 2 06-03-2008 09:05 AM
How to use a roughing end mill CuttersCov General Metalwork Discussion 6 04-18-2006 07:50 PM
Roughing/Finishing??? trevorhinze BobCad-Cam 1 08-02-2005 05:14 AM
