Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 11-02-2008, 11:34 AM
hecirp is on a distinguished road
Unhappy Trouble machining solid with BCC 21 & Mach3
The solid is a tear drop shaped fairing. BobCad21 generates toolpath which is correct.
BUT the Gcode generated has multiple lines having only a number and no other code. Mach3 will not accept those lines. When those lines are edited out, Mach 3 will mill the solid correctly, BUT only does one side (90 degrees) of the teardrop and stops.
Any idea what those lines are with number but no code (ie N250 6742)?
And why only one side of the solid is machined?
Any help would be appreciated,
Harvey Price
Old 11-02-2008, 04:32 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Harvey Price
Harvey,
Can you post your G-Code file here???
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 11-02-2008, 10:21 PM
Trouble machining solid with BCC and Mach3
Hi Toby,
Thanks for your answer. The piece is a cable fairing to be used on a large radio control model airplane. It is a half of a tear drop shape.
I have hopefully attached the BCC code (before the strange numbers removed) and the code after they were removed with editing. You can see the shape in mach3. This is a test file with a large end mill and big step downs to demo the problem, but it has happened with small ball mill and small step downs also. (about 20 times!).
Thanks in advance for taking time to help,
Harvey Price
Old 11-03-2008, 01:31 AM
GeneK is on a distinguished road
Harvey, I have ver. 20 and 22. I loaded the unmodified version in to Ver. 20 and back plotted to the CAD side and watched the position of the pointer for each step. The lines where there is a line number followed by a simple number, it seems to be that it should be the Y axis step. On the few lines I tried, adding 'Y' in front of the simple number moved the path over and began to fill the blank space in the tool path.
I'm not sure what this means but it just is dropping some characters occasionally.
Since I have never experienced this I'm not sure where to go from here, in Ver 20 under change there is a re-organize command that clean up loose end and things wrong with the geometry that can throw off the tool path.
GeneK
Old 11-03-2008, 01:36 AM
tobyaxis's Avatar
Moderator
Hmmmmmmm...... Honestly I have never seen this happen before. I did a back plot on the fixed file as you can see below.
The only reason I can think of for the software only machining 90 degrees of your solid might be a boundary issue or a solid model issue. It seems to be skipping a whole section of the solid profile for some strange reason.
Can you Post your solid model here zipped???
Name:	NC Plot file1.jpg‎
Toby D.
Schwarzwald
Old 11-03-2008, 03:01 AM
Toby, If you look at the top view of his tool path the Y axis increment gets messed up when it goes from neg to pos and the next few Y axis moves are of the form line number <space> number, with out the 'Y' and the proper decimal. So Mach 3 thinks it is all the line number and errors out for too large a line number. I entered the 'Y 0. in front of the number and the pattern began to move on as it should instead of cutting several conour on top of each other. I did not try to correct the whole file. I think the lines with ony the line number are related to the above error.
He said the code was from version 21, I have 20 and 22 and only tried it in 20.
GeneK
Old 11-03-2008, 04:16 AM
HuFlungDung's Avatar
Moderator
What happens if you turn off 'coordinates modal' in your post setup, if it has provision for that?
Old 11-03-2008, 04:33 AM
*Registered*
HMB3000 is on a distinguished road
try going to Bobcad website and first do a repair. Also delete the post and re-load from site. The software my be corrupted
Old 11-03-2008, 07:57 AM
moldmker is on a distinguished road
Harvey,
You clearly state this is V21.
On the CAM side, under Setup>Coordinates, are your Decimal Digits set to 4 places and Field Width set to 0?
Under Setup>Conversion, is there anything being filtered out?
When you generated the Planar path, what was set in the Tolerance box?
In the Tool Depth Setting box, what was set in the Max Arc Interp. Error box?
Do you get the same error when not using the Automatic Roughing?
Have you altered any of your scripts?
Are you running up against any memory issues, RAM or hard drive space?
I'm not sure any of the above could actually produce your results. But I've run into unusual output before that was caused by mistyping a number in one of the Setup boxes.
Keep us posted.
moldmker
Old 11-03-2008, 11:56 AM
The One is on a distinguished road
Along with what moldmker suggested, I would suggest going to File -> Environment. Click on General and change the General Accuracy and Chain Gap to 0.0001 for inch and 0.001 for mm.
Regards
  #11   Ban this user!
Old 11-03-2008, 10:17 PM
Trouble machining solid BCC and Mach3
Hi All,
Thanks every one for your replies. I just put in a 15 hour day at work and have another one tomorrow, so I will get busy tomorrow evening and try to zip the solid and send as suggested, and go back and make all the changes as suggested. I am using BCC 21, and don't have access to 22.
Since I posted, I exported the solid from BCC as a .igs file to a friend's Cobalt software, and exported from there as a .stl file to MeshCam (which doesn't support .igs). MeshCam generated Gcode which simulates correctly in Mach3. But it is sure the long way to get there.
I am eager to get back to this Wed, 23rd. I will have to learn to zip the solid file first since I haven't done that before.
Thank you all for your interest and support. All I can say is WOW!
Harvey Price
Old 11-04-2008, 07:39 PM
tobyaxis's Avatar
Moderator
Hi All,
Harvey Price
You can get free File Zip here. Download and install.
FilZip
Toby D.
Schwarzwald
Need Help!- Trouble Machining Ball-screw End Adamj12b General Metalwork Discussion 4 11-27-2008 04:50 PM
KelingInc and Mach3 trouble Normann Automation Technology Products 9 09-26-2008 10:12 PM
Problem- Mach3 Solid Tapping ? Anyone done it? neilw20 Mach Software (ArtSoft software) 0 08-02-2008 11:38 PM
Need Help!- Trouble Machining Ball-screw Adamj12b General Metal Working Machines 6 07-23-2008 03:12 PM
machining trouble an0n Visual Mill 4 05-16-2005 06:41 AM
