Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-21-2008, 06:12 PM
Hythos is on a distinguished road
Model to 3-view print
Hey gang -
I've been able to create 2d drawings and 3d models, though I haven't exactly figured out how to create a 2 or 3-view dimensioned print - to a title-block template.
So far, I've only printed the 2D view over an existing blank template page to get my print.
Thanks in advance!
Old 10-24-2008, 02:17 PM
What I'd like to do is print a 3-view drawing of a model including the title-block, if it's available in BobCad.
Old 10-24-2008, 07:32 PM
tjones's Avatar
tjones is on a distinguished road
Got an ideal....
Sign up for the free Alibre Xpress. It will do drawings from a solid (even an imported stp file from Bobcad). (and it has drawing templates)
The nice thing is it will do all the views and even do iso views.
www.alibre.com
Old 10-25-2008, 11:25 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Originally Posted by tjones View Post
Got an ideal....
www.alibre.com
Not to mention Free and as an added bonus Parametric!!
This should help solve your problems
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 10-29-2008, 06:00 PM
tjones's Avatar
I still do use both programs though. Bobcad has that nice little gear tool and I can save as a dxf to open in Alibre for making my solid.
Old 10-30-2008, 09:31 PM
J&RMachine is on a distinguished road
tjones, I also used Bobcad to program the machining of a gear using a 1/8 carbide endmill. It took about 4 hrs to machine my gear with 37 teeth that was .600" thick. I was only taking .050" depth of cut and running about 1.6 ipm. I tried increasing my feed a little but my cutter couldn't take it. I was just wondering, do you actually machine gears or cut them with a wire edm or something?
Old 10-31-2008, 07:51 PM
tobyaxis's Avatar
Moderator
LOL, Tjones is a crafty Machinist
Toby D.
Schwarzwald
Old 11-04-2008, 02:27 PM
tjones's Avatar
There are several ways.
You can machine each tooth with a larger mill and then finish with a small one. (3D machining if no other option only)
You can have a special tool made for single pass (I can use the geometry from Bobcad to do this). I am a tool maker so this can be done in house.
You can purchase a gear cutter from Rush Gear. I often buy the standard cutters simular to a milling cutter as it is the cheapest way for speed and time. Especially when running several gears.
I also wire cut gears very often when they are specials or need higher precision than a gear cutter will give. (this case though the part was a nylon so no wire)
Hobbing. Requires a hob and hobbing machine (we use to make loads of gears like this back when we actually could get jobs in the USA)
Grinding. Required for high precision. I have the software to CNC grind gears but our 4th axis on our Jungner grinder does not have scales for the accuracy required.
There are more but none I have used.
How to print ion a 3d surface whiteriver Printing, Scanners, Vinyl cutting and Plotters 3 01-20-2010 03:39 PM
cant print? erase42 BobCad-Cam 13 11-30-2009 08:05 AM
0.8 um Symbol on print ? RMARCH General Metalwork Discussion 4 11-30-2007 09:55 PM
RFQ Create Solid Model from Part Print Jim Estes Employment Opportunity 0 06-15-2007 01:22 PM
2d print from solidworks Kool Parts Solidworks 7 02-03-2005 09:12 AM
