Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-20-2008, 02:53 PM
orizaba is on a distinguished road
translating a contour
After I finished drawing a part, I translated it over to x axis, and saved it. Later, I deleted one of the contours and it disappeared, but the underlying geometry moved back to its location before I translated it. I have run into this before,and just worked around it. This time I'm stuck. Why does the old geometry show up in the origional location when I delete the contour?
Matt
Old 10-20-2008, 03:43 PM
*Registered*
HMB3000 is on a distinguished road
Originally Posted by orizaba View Post
, but the underlying geometry moved back to its location before I translated it. Matt
Matt when you make a contour and transale it. your only copying the first contour not the underlying geometry. the underlying geometry is blanked out by the first contour. But it is not copied and transaled with the contour
Old 10-20-2008, 04:09 PM
Thanks. I will wait until I have the part where I want it, then create the contours.
Thanks again
Matt
Need Help!- Bad contour error apylus444 BobCad-Cam 2 10-03-2008 02:25 PM
Need Help!- Swept 2d Contour mrsammy Mastercam 15 09-29-2008 11:12 AM
Need Help!- Swept 2d contour mrsammy Open Source Controller Boards 0 07-05-2008 11:22 PM
Great diy board (I tink is russian) żAnybody interested in translating? patriciooholegu Open Source Controller Boards 3 05-26-2008 03:20 PM
HELP! Wireframe contour neilw20 Mastercam 4 02-16-2008 12:25 AM
