| BobCad-Cam Discuss all BobCad software here. |
I use Bobcad V22 pro in millimeters. I have big problems with my milling tools menu. When I add new tools the feed and spindle speed is not listed correctly in my cam tree. I also have problems with feed and spindle speed in the cutting-conditioning table. When I for example set the milling parameters to suit a 10 mm end mill and then try to use a 2mm end mill, spindle speed is okay but feed is way to fast. The program does not account for large and small mills as I think it should. Have Any of u had these problems ?? |
| Use the Manual Overrides for Speeds and Feeds to eliminate this problem.
| I found that when I changed values in the cutting conditions that it didn't always change the speeds and feeds in the CAM tree when I check straight after. I think closing down bobcad after changing the cutting conditions and then opening up again helped. |
you are correct any changes to setting defualts will not work untill you close and re-open. This enclude things like backround color |
| I wonder if it will be fixed in V23???? Then again V23 will not even be purchased due to the problems with V2007/aka V22. Oh well............
| Feeds and Speeds | tac8357 | Mentors & Apprentice Locator | 1 | 06-26-2008 09:50 AM |
| Speeds n Feeds | jessbussert | WoodWorking | 12 | 06-12-2008 11:09 AM |
| Need some help with speeds & feeds | ldkell_2000 | General Metalwork Discussion | 6 | 03-01-2008 10:35 AM |
| Need Help!- speeds and feeds | rodzilla | Benchtop Machines | 3 | 02-19-2008 10:30 PM |
| feeds and speeds | Mortek | Hard and High Speed Machining | 6 | 02-28-2004 03:59 AM |
