Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 09-23-2008, 02:14 PM
chromic20 is on a distinguished road
Smile v22 mold cavity help
So I am trying to cut a mold cavity, I have been able to make z level rough and z level finish work by selecting the entire model. I am now trying to get into the little spots with a smaller cutter. I would rather not try to finish the whole cavity with the little .094 cutter so I am trying to select only the surfaces that need cutting. When it generates the tool path, it wants to cut outside of the cavity as if it where cutting both sides of the specific surface. If this makes sense, any help would be much apprecieated.
Also, When I try to use any of the slice planar or equidistance functions to finish the bottom flat surfaces of the cavity, it seems to think it is a male rather than a cavity and it wants to cut the surface larger than what the cavity should be. I have tried changing all the settings but no luck.
Old 09-23-2008, 04:47 PM
moldmker is on a distinguished road
It's usually best to select your WHOLE model as your geometry then isolate the cutting area with Boundaries and/or Stock.
Use Stock for Z-level and Boundaries for the other 3d features. (Careful, the Stock creation sometimes works goofy)
Boundary curves can be created by Extracting Edges from the model then project them to a temporary surface above Z. (Not necessary but it helps)
Put them on a separate layer so they can be easily hidden.
You usually have to manipulate the extracted edges in order to make a boundary that allows the desired toolpaths.
Good luck,
moldmker
Old 09-23-2008, 05:07 PM
thanks a bunch, I have to sit down and figure out boundries and I think I will be good to go.
Need Help!- create mold cavity Rob 1264 SolidEdge 0 05-09-2008 11:04 AM
Mold cavity insert question dav612 Moldmaking 15 11-18-2007 10:55 PM
Mold cavity kojack MadCAM 1 11-01-2007 02:22 PM
Making a positive mold from a negative mold - how? SRT Mike Moldmaking 7 03-29-2007 04:30 PM
OneCNC XP Expert - Mold Cavity OneCNC OneCNC 7 12-10-2003 02:22 PM
