Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 09-14-2008, 11:11 AM
DonW is on a distinguished road
Curved bottom slot?
I can't seem to figure this one out, so I figured I'd ask for some help.
I'm trying to figure out a way to create curved-bottom slots for frets on a guitar fretboard. I'll be starting with a 5/16" thick part, which will be cut to a 16" radius along its length. Once that is done, I will be cutting fret slots that are .023" wide, .09" deep, but I want that depth to follow the curvature of the top of the fretboard. The cutter will be .023" dia, so it will be a straight cut, but as I said, I would like to not have a flat bottom. I can't seem to find a function that will work. I can't seem to get a pocket or a profile to work, and am not having much success with trying to create a surface that will work either.
While I'm here, does anyone know if there's a way to add some transparency to the Predator simulation in the Verify function? It would be nice to be able to see into the part during the simulation.
Sample file attached...the blue curves represent the 16" radius, and the green curves are the slot bottoms I'm hoping to get.
Thanks.
Old 09-14-2008, 12:19 PM
bborb is on a distinguished road
I would fixture the part oriented vertically and the surface you want to cut hanging out of the end of the vise, then use a .023" slitting saw/key cutter and cut the fret slots with G02/G03, dropping down in Z for the next fret slot.
Old 09-14-2008, 12:48 PM
I guess I should clarify....
My cnc is a wood router, not a mill. But more importantly, these slots are blind slots, as in they don't go all the way to the edge of the part. They stop roughly .09" shy of the edge, therefore I can't use a slotting saw to cut them. Otherwise, I would simply cut them on my table saw with my slotting setup. This is very different, and must be cut with an endmill. Essentially, this could be a slice planar cut, except that it's only a thin straight line that I'm cutting instead of a larger surface...a single pass, dropping down incrementally until it reaches the .09" depth.
Old 09-18-2008, 02:25 PM
Is the bottom of your slots an arc? If so, explore G18 and G19
Old 09-18-2008, 02:51 PM
Got it working
I had to use the 3D Engraving command to get it to work right. The problem with that particular command is if you have to make the cut in a few passes, you have to create separate tool paths for each pass. Not a big deal, but it does work.
Thanks.
cutting a slot with a t-slot cutter cncuser1 Mastercam 11 09-09-2008 09:02 PM
Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? weaston General Metalwork Discussion 7 04-11-2007 09:00 PM
Bottom Up approach lsilva Benchtop Machines 4 03-03-2006 11:37 AM
Milling top and bottom? bigvinney General Metalwork Discussion 7 01-28-2006 09:16 AM
Look at my bottom Graham S DIY-CNC Router Table Machines 21 12-14-2004 02:12 PM
