| BobCad-Cam Discuss all BobCad software here. |
I basically have a square block with a boss in the middle of it. I want to use a flat endmill to rough it out. It cuts the boss way undersize and I am not sure why. I generated the tool path, incremented it down half the tool diameter(maybe this is where I went wrong) then inserted NC and made the program. I made sure the tool technology was right. What else did I miss?? I like to use a flat to rough with since it is faster. |
| Maybe list the code here showing the code just prior to the roughing cycle? Al
| I have had this problem before. Anytime I want to use a flat to rough with, it cuts any features like a boss way undersize. I stopped doing it that way but would like to figure out how to make it work.Also is there a way to control how much rough stock is left? |
| I don't know if this will help you or not. I'm getting pretty rusty on Bobcad these days. But, it seemed to me that when you were pocketing you picked the profile and then the islands (the bosses you speak of). The location of the cursor when you picked the islands was critical to the outcome you got for a toolpath. Make sure your cursor is on the outside of the islands. Even then, you need to watch where you place the cursor before you "click it" to select an island. If you have more than one island, you may need to experiment a bit with various cursor locations to get a desirable outcome.
| fastolds, Try extracting the edges of your part then project them to a flat plane. Once they are 2D you may need to do a little clean-up, but afterwards you can simply use the pocket function. Also, which version of BobCAD are you using? Dependant upon the version you may have other options. For instance, the Spiral solid toolpath in V20 will allow you to select one profile and one island for boundary machining. Regards |
#10
| how can i generate G-code from a dxf file? what should i do with the format of the dxf file once i inserted it into the CAD side? delete or leave it? (i used solidworks as my solid modeling software). thanks hau |
| efficient tool path | balsaman | Mastercam | 32 | 07-28-2006 11:37 AM |
| Laser tool path display....( IDEA ) | ynneb | DIY-CNC Router Table Machines | 41 | 04-10-2006 10:19 PM |
| getting tool path problem | kenlambert | BobCad-Cam | 0 | 01-14-2005 02:15 PM |
| Tool Changer Problems | Snel | Haas Mills | 5 | 08-11-2004 08:56 AM |
| tool path generation BobCAD V18/19 | inthedark | BobCad-Cam | 3 | 02-10-2004 09:14 PM |
