| BobCad-Cam Discuss all BobCad software here. |
| MACHINING ALUMINUM 6061 USING A FADAL 4020 AND BOBCAD V20. I NEED TO GET A NICE SURFACING FINISH, WHAT SPEED, FEED, STEP OVER, TOLERANCES, Z DEEPTH, ETC NEED TO USE . I ALREADY TRIED ON 2 PARTS AND STILL GETTING A BAD FINAL FINISH. ANY RECOMENDATION WILL BE APPRECIATED. |
| Ok, I'll give it a try. What type of geometry are you finishing? (a surface, 3d geomotry, etc..) How smooth do you need it to be. I have found that when the mill is trimmed correctly, and I have a GOOD endmill, I can almost get a mirror finish if I take .015 on the finish pass when facing the bottom of a pocket. I usually cut 7075, and I'm not a machinist (hobby cutter ), so this my be bad advice |
| if it is a flat surface ditch the ball end mill use a 2 or 3 flute 3 flute would be better tin coated and a new end mill crank your mill all the way up as far as spindle speed use a feed of 3.0 per and a good coolant and flood it good .and a depth of cut of .010 this should greatly inprove your finish.just my two cents. |
| RoboFac Details | SimonArthur | CNC Wood Router Project Log | 53 | 02-15-2010 10:53 PM |
| hiwin cad details | eloid | Linear and Rotary Motion | 2 | 12-30-2009 08:20 PM |
| What Bit for fine details? | teamtexas | DIY-CNC Router Table Machines | 0 | 05-11-2008 09:15 PM |
| G73 Details/ Explaination | nelsonrb4 | General Metalwork Discussion | 1 | 05-02-2007 02:29 AM |
| Sub.: Constructional details of CNC | sanganaksakha | General Metalwork Discussion | 2 | 05-31-2006 10:00 PM |
