Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-10-2004, 11:04 PM
fastolds is on a distinguished road
cutting oring groove
What is the best way to cut just the oring groove?
Old 10-10-2004, 11:49 PM
DSL PWR is on a distinguished road
in a shaft or a plate?
Old 10-11-2004, 12:55 AM
To make things simple, say I have a square block and I want to cut the .140 wide oring groove around the perimeter without cutting everything around it.
Old 10-11-2004, 04:04 AM
*Registered*
ESjaavik is on a distinguished road
Use a ballnose cutter, run it in a square somewhat smaller than the perimeter.
Old 06-17-2005, 02:26 AM
Dave257 is on a distinguished road
oring
I put the tool in the middle of the groove at the end of a line. bring it down slow, I go .001 in ss and ,005 in alum. When you get to the depth you want (don't try to do it in one pass as to break the endmill.)Then just use cutter comp, I use cutter left, go to the start of the line you came in at on the left. , comp around, take off cutter comp using half the groove with for lead out, cutter comp the other side going the other way. I can hold a groove to .0005 in width doing it with cutter comp, but not using comp, you have to have the endmill size, and any other variable that will make the cutter run out . This is only possilble with version 20 using the profile contour by the way. I don't think the earlier versions were capable of setting comp very good.
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
Cutting metal signIT DIY-CNC Router Table Machines 2 02-19-2005 11:14 PM
CNC router deflection calcs and cutting loads? Linus DIY-CNC Router Table Machines 1 09-10-2004 10:08 AM
Best tool for cutting metal? PsyKotyk General Metalwork Discussion 4 04-01-2004 02:10 AM
Do you account for climb cutting in G code? fyffe555 DIY-CNC Router Table Machines 12 11-06-2003 07:21 PM
