Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 08-28-2008, 06:28 AM
msomerville is on a distinguished road
converting imported part drawing to mold drawing
First off I am still using ver 21. How do you guys quickly convert the part (solid) your customer sends you to a mold drawing. I can stumble around using boolean functions, but I was wondering how you guys would go about it.
Old 08-28-2008, 01:04 PM
etzz is on a distinguished road
In a different program that I use, you can automatically generate 2D drawings from solids. Not sure if BC has that feature, but I can see where it sure saves a lot of time.
Eric
Old 08-28-2008, 01:57 PM
Eric
Which program would that be?
Old 08-28-2008, 10:32 PM
Rhinoceros (www.rhino3d.com). Not really a competitor to Bobcad anyway. I would think its a common function in CAD software these days. Bobcad is more of a CAM program, but it may have the feature. Hopefully some Bobcad users will chime in (ive tried the demo for 21 and 22).
Regards,
Eric
Old 08-28-2008, 11:37 PM
judleroy's Avatar
judleroy is on a distinguished road
How you break a mold up depends on what your making. You may need only 2 pieces for your mold. You also may need 10. How you break it up depends on what your molding.
judleroy
Old 08-29-2008, 06:54 AM
It will be a 4 plate transfer rubber mold.
I was wondering after you would receive the solid what functions do you use in Bobcad to create your mold drawing. Would you use the boolean function? Are there any other ways to reverse the surfaces? So say that I want the ID of your part to now be the OD on your insert.
Old 08-29-2008, 06:56 AM
Regards,
Eric
I have downloaded the eval. version of Rhino, but haven't had too much time to play with it.
Converting drawing for Burny CNC Plasma Cutter Turbo1zz CNC Plasma and Waterjet Machines 5 01-12-2010 04:11 PM
Need Help!- Cirles embeded behind my drawing when imported into Mach3 Mick40 Mach Plasma / Laser 2 02-16-2008 03:29 PM
Drawing on my CNC monte55 DIY-CNC Router Table Machines 4 01-18-2008 01:10 PM
Part->Block->Drawing-> Dimension cncuser1 Solidworks 3 11-26-2007 02:22 PM
Is making a part as easy as drawing it in 3d? randyf1965 JGRO Router Table Design 13 04-05-2006 07:23 AM
