Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-30-2008, 06:44 PM
LenMcC is on a distinguished road
BobNest block nesting?
Is there such a thing? By "block nesting" I mean that BobNest will recognize an imported part almost like a bitmap, so that a triangle would nested like a rectangle. In other words, if my part is a right triangle that is 6" wide x 6" long, BobNest would nest them the same way as if they were 6"x6" squares. Please let me know if that doesn't make sense...
Old 07-31-2008, 02:37 PM
The One is on a distinguished road
The BobNest system can do what you are asking. You have to set it up so that the shapes do not get rotated. That is pretty much all there is to it.
Regards
Old 08-01-2008, 08:51 AM
interesting... what you showed is what i want. i was thinking maybe bobnest would try staggering the parts, but maybe that wouldn't make sense. thanks!!
Old 08-01-2008, 09:35 AM
It will only stagger the parts if you allow for a rotation.
The system actually works on a grid when No Rotation is permitted. The only time you should see a stagger is if you have additional shapes that will fit into an area between your primary shape.
Regards
Old 08-04-2008, 04:26 PM
I tried the nesting with no rotation, and pretty consistently I run into a problem where BobNest still tries to stagger the parts (see images 1 and 2). The reason it is important to block nest in our situation is because these parts are being cut out of perforated (diamond-shaped) aluminum, and I'm cutting along the geometry of the material in order to get smooth edges. The third image is what I want... Everything lines up in the x- and y-directions. The third image is a screen shot of the Torchmate CAD, but I'd like to use BobNest because it's a stronger program.
Newbie- Importing groups of parts to BobCad and BobNest LenMcC BobCad-Cam 5 07-31-2008 02:07 PM
BobCad - BobNEST support millman52 BobCad-Cam 2 09-09-2007 08:28 AM
BobCad-Cam With BobNest anyone using software? millman52 CNC Plasma and Waterjet Machines 8 01-22-2007 08:19 AM
2D On-Line nesting - Nesting on-demand ! mijo Product Announcements & Manufacturer News 0 03-21-2006 09:42 AM
Bobnest Scott V BobCad-Cam 1 07-08-2004 07:03 AM
