Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-28-2008, 09:42 PM
spock is on a distinguished road
plunge feedrates?
Anyone know why (ver 22) z-level finish, that the code is posted with only the cutting feedrate, and not both the plunge feedrate and the cutting feedrate? I rarely plunge at the same rate as I cut in x/y. I tried it with 2 of my mill posts, same result.
It was working fine before the update.
Old 07-29-2008, 01:24 PM
The One is on a distinguished road
spock,
In most cases when doing a 3 axis cut it should be using the X/Y feedrate and not the Z feedrate.
There are cases where this is not true, like when you are cutting a vertical wall or steeply angled wall, but those cases do output the feedrates correctly.
Would you be able to post the file for review?
Regards
Old 07-29-2008, 01:52 PM
On a z-level finish path, you step down in z and then cut in x/y (of course you know this). Having control over the step down feedrate is critical in my moldwork and hardmilling. I had this issue with one of the releases months ago, I went back to a previous release that posted the two feedrates and never updated at all until this last patch. I do alot of faces that have less than 1/2 degree draft, (nearly vertical) I was getting code before that reflected my choice of feedrate in z and x/y.
Do you want a cad file of the solid? or code? I dont know how to post it here, but I can email. Send me your address and exactly what you want to look at, I'm at shopprints@hotmail.com.
newbie Heidenhain tnc feedrates bigtoad170 Bridgeport and Hardinge Mills 2 04-25-2008 08:18 PM
G0's and Feedrates??? Moondog Machines running Mach Software 5 04-18-2007 03:26 AM
Feedrates spindle speeds and tooling Patrick_H WoodWorking 5 02-13-2007 10:17 AM
Anyone got any X1 recommended feedrates... digits Benchtop Machines 6 10-03-2006 05:54 PM
X1 Feedrates etc... itsme Benchtop Machines 2 08-19-2006 07:37 PM
