Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-25-2008, 04:54 PM
mikeh78's Avatar
mikeh78 is on a distinguished road
Stock size? new patch
Is anyone else having trouble with the stock size in the new patch?
I seem to be getting a scaling issue. If I draw a rectangle for stock it creates a block several times the actual size and if it is not centered on x0 y0 it also moves along the axis the same scale. If I had to guess it is around 5x scale.
Mike
michael.hesse@hessemachine.com
www.hessemachine.com
Old 07-25-2008, 05:29 PM
smurph is on a distinguished road
Yes, there is a problem there. I've run into the same thing. If you don't have to have the stock, just delete it's geometry and verify will work fine. Otherwise, you can try and make miniature stock for the time being.
How about the new pocket entries? Those made my day! The rest of the update seems to be working really nice! I had a part that I could make the old release crash with every time, but not now.
Steve
Old 07-25-2008, 05:30 PM
moldmker is on a distinguished road
Yep...same problem.
What should be a 2" cube looks like 40" x 40" x 2" thick plate in verify.
It seems to be related to whether Stock is defined or not. When I don't define the the Stock, Verify is OK.
Someone know of a parameter setting?
moldmker
Old 07-25-2008, 05:34 PM
mikeh78's Avatar
Good it's not just me. I looked at all the settings I could find and I couldn't find anything to scale it.
Smurph:
The new features are pretty nice, and I have only had 1 crash so far. and I think it was the way I was trying to do something.
Mike
Old 07-27-2008, 09:04 AM
MSPP is on a distinguished road
Question Stock size problem
I'm having the exact same problem with stock size that is discribed by the other guys. Verify is fine but that's not what we paid for, is bobcad working on this issue? Just so its said with the exception of the stock size problem the rest of the software update works fine!
Old 07-27-2008, 05:21 PM
OK... Here's what Bobcad thinks the stock size is when I pick on the small circle in the center of the screen. Doesn't matter if I'm in metric or inch.
Verify must be picking up on this for it's block size?
I'm sure on Monday someone from Bobcad can address this...
Old 07-27-2008, 05:24 PM
I'm sure they are working on it. It was reported it to support the day of the update.
Steve
Old 07-27-2008, 06:41 PM
highspeedmazak is on a distinguished road
It seems like this version is pretty bad compared to v21 so I am back on v21. Other systems are looking cheaper by the day.
Old 07-28-2008, 09:34 AM
The One is on a distinguished road
The Stock size issue was reported and is being addressed. The scaling is by units. For some reason it is scaling by 25.4. It will be addressed soon.
Regards,
Chris R.
Old 08-22-2008, 02:07 PM
Regards,
Chris R.
Based on the above, I was able to get correct results by scaling down the geometry by 1/25.4 first, then picking it.
I posted this on the Bobcad forum, as well.
moldmker
Build Thread- New V22 Patch on the way CNCdude BobCad-Cam 135 08-13-2008 09:25 PM
Need Help!- Need a patch for Ez-cam for Lathe Exodus8931 General CAM Discussion 2 07-08-2008 11:57 AM
Defining Stock Size In BobCADCAM jonbanquer BobCad-Cam 3 01-25-2006 06:58 PM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 09:16 PM
Bobcad has a new patch released HuFlungDung BobCad-Cam 2 06-10-2003 11:04 AM
