Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-24-2008, 12:26 PM
LenMcC is on a distinguished road
Importing groups of parts to BobCad and BobNest
I'm orienting myself with BobNest 3.0, and it seems like a good program. One thing I haven't been able to figure out through trial-and-error, BobNest help, or the forum is how to import multiple groups of parts.
I have groups of parts containing 2 to 6 parts each that were saved as dfx files in SolidWorks. I can open a file in BobCad and then import the group of parts to BobNest, but I haven't been able to open "Group A" and "Group B" together in BobCad before sending them to BobNest. Any pointers?
Old 07-24-2008, 12:44 PM
The One is on a distinguished road
Use the File Merge option. That will allow you to bring the data from a file into another and can be used as many times as is necessary. Be careful with placement though, because it can cause an issue for selection.
Regards
Old 07-24-2008, 02:46 PM
Ok, I was on the right track at one point. Yeah, my problem was placement, then. Is there an easy way to shuffle parts without using CHANGE>TRANSLATE>DRAG? 6 clicks or keystrokes is 4 or 5 too many. I tried modifying the toolbar to have translate on there, but was unsuccessful. is there a keystroke to drag and drop shapes? e.g. ctl+drag? I tried a lot of combinations with dragging and tried some with the arrow keys.
This is BobCAD V21.5.3, if that helps. Thanks!
Old 07-29-2008, 09:26 PM
Claude Boudreau is on a distinguished road
Importing files
Im new to all this but maybe using different layer and blanking option on imported files could make thing easier.
Using translate / increment, to a free spot on your screen can save a few stroke
Old 07-30-2008, 06:35 PM
can i do that without using the CHANGE drop down on the menu bar?
Old 07-31-2008, 02:07 PM
You can setup a Hot Key to activate the translatre function.
Click on Special/NC-CAM => Record Script => Menu Configuration.
Make sure that CAD is the selected menu type.
Change Menunumber level 1 to 2, this moves the focus over to the Change menu.
Change Menunumber level 2 to 2, this moves the focus to the Translate function in that menu.
The Menu Text field will say &Translate.
Below the Submenu field you will see a field that allows you to assign a Hot Key. Input the letter here that you wish to use to access the fucntion. Be careful not to use any letters already associated to functions, like the A, B, C, X and V buttons. the Ctrl + is normaally added automatically.
Hope this helps.
Regards,
Need Help!- Importing parts from china eloid Want To Buy...Need help! 0 03-12-2008 01:17 PM
importing .jpg as .dxf/.cad into bobcad nordy BobCad-Cam 16 10-15-2007 05:48 PM
BobCad - BobNEST support millman52 BobCad-Cam 2 09-09-2007 08:28 AM
BobCad-Cam With BobNest anyone using software? millman52 CNC Plasma and Waterjet Machines 8 01-22-2007 08:19 AM
Importing polygon mesh (.dxf) into BobCad rherman BobCad-Cam 0 06-10-2005 02:08 PM
