Results 1 to 5 of 5
Thread: *Easy* V21 point translation question. :)
    Jul 2005
    Hello all,
    It's pretty fair to say I'm a very low-ranking n0oB in the world of CAD/CAM, so please go easy on me.
    Here's my question:
    I've taken a point cloud with my Microscribe G2 and BobCad V21. The points are correct as far as X/Y is concerned, but the Z values are innacurate and not relevant to my project. I need all of the points Z values to be set to ZERO (making the part 2D).
    I know I can translate individual points down to Z zero, but this will be quite time consuming. Can points be "flattened" down to Z zero in groups?
    Many thanks for reading this, and hopefully providing some insight to my confusion!
    Alan
    Mar 2005
    1. Make sure everything is unselected.
    2. Select 3D > More > Move to Z...
    3. Selection Type = Region, Z level = 0 (or as desired), Relative = Off
    4. Window around your pointcloud.
    Everything should now be at same Z-level.
    Microscribes are great tools for reverse engineering!!
    Good luck
    moldmker
    Jul 2005
    Moldmkr,
    Thanks very much for the quick and thorough reply!
    This will be much easier than modifying each individual point, that's for sure.
    Your help is greatly appreciated,
    Alan
    Jan 2007
    Can you do a similar thing in V22?
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Mar 2005
    Nope.... At least not that I've found.
    There's a Project Curves to Surface but that doesn't work with points.
    Just another feature that was eliminated when "updating" to V22.
    moldmker
    1. easy wiring question
      By swarfmacdaddy in forum Stepper Motors and Drives
      Last Post: 01-12-2008, 05:01 PM
    2. file translation please
      By TR MFG in forum Solidworks
      Last Post: 11-29-2005, 12:13 PM
    3. X translation problem
      By fhadk in forum Mastercam
      Last Post: 10-29-2005, 10:17 AM
    4. easy to answer question
      By senor J. in forum Mach Software (ArtSoft software)
      Last Post: 01-27-2005, 07:34 PM
