Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-13-2008, 01:54 PM
journeyonline is on a distinguished road
Question How to control the starting point of a pocket
I'm running a test cut on a rectangle 2"x3"inches with .25" radius but can't seam to make the tool start in the center of the line, versus starting at the radius. How do you change were the tool starts?
My control will fault or error if I start the cut on a radius.
Old 06-13-2008, 03:27 PM
orizaba is on a distinguished road
V22 will start at the end of the line selected. For a profile Break the line in the middle and reselect the contour so that the arrow is not in the corner. If its a pocket select "center out". (I think)
Old 06-16-2008, 03:31 PM
Thank-you I will give it a try. Currently I have version 21 and V22 but only use the V21 since I'm still learning it.
Old 06-16-2008, 05:51 PM
Also, with V22, If you place a point in the pocket, the start point option will be avalible for selection. ( If memory serves me correctly - I'm not in the shop to double check.)
Old 08-13-2008, 09:15 PM
oxford's Avatar
oxford is on a distinguished road
Correct.
Just sketch of plot a point and then select it as the start point.
Hit the right but when you click the "start point" icon and then click the select/reselect tab. select the point you wan then right click on the screen to click "ok"
Need Help!- STarting NEw project - Need Serious Help to Understand PArts before starting osix DIY-CNC Router Table Machines 2 06-30-2008 03:54 PM
Z Axis Starting Point in DCAD Execute/Simulation jim_stoll Dolphin CADCAM 1 09-16-2007 02:08 AM
here is starting point for the new guys spider Casting Metals 3 09-10-2006 12:10 PM
Best starting point for MC 7.2 to Mach2 see2nen Post Processor Files 4 09-01-2006 08:21 AM
Home, zero, starting point... saturnnights General CNC (Mill and Lathe) Control Software (NC) 4 02-14-2006 02:57 PM
