Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-02-2008, 12:50 PM
orizaba is on a distinguished road
Preadator 7.0 defaults
How do you change the default settings. Baud, stop bits etc? I have to change several settings each time I send a file.
Thanks Matt
Old 06-05-2008, 02:22 PM
Sowen is on a distinguished road
The default settings are ussually saved when you exit the software , check and make sure that the predator directory is not set to read only in windows.
1. Open predator
2. click on DNC_Properties
3. Make changes , click next , until finish is an option click finish
4. close predator
5. open predator the changes should be there
If they are not click on my computer go to C:\program files \ predator
right click the predator folder go to properties then uncheck read only and apply this to all subdirectories.
If this does not work let us know
Old 06-06-2008, 10:38 AM
1. Open predator
4. close predator
If they are not click on my computer go to Crogram files predator
Thank you
I have been doing steps 1-5 and the steps are not saved. I'll do the other tonight and let you know, Thanks again
Matt
Mastercam x2; Help! Coolant always defaults to off. L.Kiefer Mastercam 15 12-27-2007 02:02 PM
Rhino_Tools_Options Defaults? robinsoncr Rhino 3D 2 06-12-2006 11:07 AM
