Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 04-26-2008, 10:38 AM
orizaba is on a distinguished road
Z finish question
Last night while using the z finish, I needed an XY move then a -z but it did it as a combined move, leaving a nice little ramp. subsequent moves were correct. When I looked closely at the tool path, it shows the move within the part. When I recalculated the tool path, it as still there. It didnt ruin the part, but might next time.
How do I prevent this with out looking at each line of code?
Matt
Old 04-26-2008, 04:52 PM
moldmker is on a distinguished road
Did you mess with the Process by Level and Process by Area to see if it made any difference in toolpath?
Sometimes even changing Cut Amount by a little will alter the paths.
The toolpath may have ramped just because it was in an area that would be machined away. Most 3D cutting requires either ball or center-cutting end mills because of this.
Just some thoughts. May not be the solution.
Good luck.
Old 05-05-2008, 01:10 PM
'nother question
When using z rough to cut a .1 pocket with a .09 endmill. I divided it into 4 .025 passes with .01 left for the finish pass. The first pass was located at z+.01, the second at z-.015, then z-.04, then z-.065 then z-.09.
My question is why it there a tool path above the work? I just deleted the 10,500 lines of code that were above the work, and cut the part with out a problem.
I found the same thing with slice radial
Matt
Old 05-06-2008, 08:04 AM
The One is on a distinguished road
The Finish allowance field is used for X, Y and Z. So when you tell the system to leave n amount for finishing, it does it on all surfaces, including the flat surface at Z0.
As for the ramp that appeared in the path, it would likely have to do with the linking type selected and the facetting of your model. If you want to post the file, I can look at it and see if there is any other reason for this happening.
Regards
Old 05-07-2008, 12:47 PM
Regards
thanks for the help,I have the tool path I need now. I'm sure I will have more questions later though.
Matt
Finish on M2 yoopertool Mass finishing equipment/media/stratigies 2 03-26-2008 07:43 AM
Paneling question start...finish abelloise ArtCam Pro 3 12-03-2007 12:09 PM
How to get this finish dneisler General Metal Working Machines 3 10-11-2007 08:09 PM
Newbie question: what's causing this finish? Involute Syil Products 12 06-18-2007 05:08 AM
Finish Cut How too ??? Biggermens BobCad-Cam 6 04-30-2007 08:59 PM
