| BobCad-Cam Discuss all BobCad software here. |
| Hole Making with v22 I have run into this a few times before and just edited the code to suit my needs. I figured I would ask and see if there is a way to eliminate the need to edit. Is there a way to make a hole or perform an operation to an existing hole without going through all the added tools? Let me see if I can explain this a little better. Here are the two most recent encounters I have had: 1. I am cross drilling an .070" hole in a cylinder that is off the centerline of the cylinder. I have put the cylinder in a square fixture and am going through hardened drill bushings in the fixture. 2. I have a part that requires a pre-drilled hole to be reamed. Obviously, with #1 I cannot use a centerdrill. And with #2, I have no need for a centerdrill or a drill. What I have done in the past is just use the Centerdrill feature and then edited the tool info and speeds/feeds in the program. When I choose a hole-making feature, how can I eliminate these things so I can just use a drill or reamer? Thanks in advance. |
| In Cam tree under Cam part: Right click Milling tools. Click Default(or Part if you only want the change for current file)>Tool Pattern Pick Hole (or Reamer) and you will be able to delete the unwanted operations. Save the file right away so it sticks. I think others have altered lesser used processes to be a drill only command and left the Hole command intact with center drill. But since the processes cannot be renamed it may lead to confusion. Good luck |
| Very nice! Thanks a ton. |
| Tags |
| changing drill features, drilling holes |
| NEWBIE HELP>> How do you input a drill hole or extrude a hole that is.. | l u k e | Solidworks | 9 | 02-11-2008 11:54 AM |
| How to tap a hole? | alexccmeister | General Metal Working Machines | 5 | 05-28-2007 05:25 AM |
| How best to cut a hole in CNC. | cameraman32 | Benchtop Machines | 6 | 03-23-2007 01:07 AM |
| Making a hole on an angle | skmetal7 | PTC Pro/Manufacture | 1 | 03-19-2007 05:00 PM |
| drill hole | larry53 | General Metalwork Discussion | 8 | 05-19-2006 07:50 PM |
