| BobCad-Cam Discuss all BobCad software here. |
I'm new to using offsets in Mach 3 and want to start running some of my CAM based on a G55 offset. How can I change BobCAD to export my GCode as a G55 offset (versus the default G54)?
__________________ Tormach PCNC 1100, SprutCAM, Alibre CAD |
| You really don't need to do that. All you need to do is a Find and Replace in the Editor or in NotePad/WordPad. Find:G54 Replace with: G55
| Toby - that's what I've been doing, but it adds an extra (unnecessary) step between exporting my GCODE from Bobcad and opening it in Mach3. If it's the only solution, so be it. I would think BobCAD would allow me to "tell" it to run a certain program with a certain offset. Is this a common feature in other CAM programs?
Personally, I like to fine tune Programs for efficiency and other little things.
| I found a bug in the program related to this, even if you make another post processor, say a g55 post, and then close bobcad, then open it back up, even if the g55 post is shown, it will post to the g54. Check the output to mach. If anyone has a minute to verify this on your side, I would appreciate it, cause it drives me crazy I almost crashed my endmill into my fourth axis (I run four axis at g54, vise at g55 |
| If you are running V22 you could hard code the G55 in the post. You do this by not calling the variable but using " " instead this will hard code the G55 into your programs. If you are ruing V23 you can choose what work offset you are in. Also the just release the save a load feature item which means you can setup a feature and setting save it and load it as needed. Great for drilling and setting up tool set over and depths for different materials ! Go BobCAD ! |
| Radius Offset and Length Offset | jim_stoll | Dolphin CADCAM | 13 | 10-14-2010 08:47 PM |
| FANUC 3M G54 OFFSET, H-OFFSET----Please help!!! | cjchands | Fanuc | 2 | 05-25-2009 12:22 PM |
| No offset | CNCadmin | LazyCam | 4 | 08-13-2007 01:28 PM |
| OffSet? | CharlieM | G-Code Programing | 11 | 11-08-2006 10:56 AM |
| X offset | chrose | Mazak, Mitsubishi, Mazatrol | 4 | 03-18-2006 04:16 PM |
