Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-31-2008, 07:20 PM
elmi is on a distinguished road
knurl on a solid?
Hi folks, I'm trying to create knurling on a solid without any luck.
I created a cross hatch and then tried every surface creation possible.
I am not having any luck. Any ideas?
The part is basically a thumb screw.
Thanks.
Old 03-31-2008, 07:51 PM
cam1 is on a distinguished road
Hi:
Alot of the time a note is just made on the detail drawing with the callout for the knurl.
regards
Old 03-31-2008, 08:50 PM
That would be much easier! Thanks.
Old 03-31-2008, 09:35 PM
*Registered*
Mike Stevenson is on a distinguished road
Solid Knurling is possible but because of the intense detail (geometry) that knurling creates, it will inturn create huge, unwieldy, files that consume a lot of your computers resources. The same goes for Springs and Threads.
Old 04-04-2008, 07:52 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Maybe you should take a look at Alibre V10 Professional. This part is only 819kb with a thread. the thread was created using a Helical Cut.
The Boat Propeller is only 3.87mb using a Helical Boss.
These are PDF files. Give them a Spin, LOL.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 04-04-2008, 08:35 PM
*Registered*
Toby,
Got a Knurling example?
Old 04-04-2008, 10:38 PM
tobyaxis's Avatar
Moderator
Toby,
Not yet I just started using Alibre as a full time CAD Modeler. I'm sure it is possible and just as easy to do as the PDF's above.
Toby D.
Schwarzwald
Old 04-05-2008, 05:43 PM
moldmker is on a distinguished road
It can be done.
Used Extrude Curve with draft to form single knurl point.
Translate and rotate to position correctly to axis.
Rotate with copy to form single row of knurl points.
Translate/rotate to form second row.
Translate copy to repeat pattern along length of axis.
Create Planar Surface caps on ends.
Stitch all to single solid.
.500" dia x .800" long.
4 mb file size.
Good luck
Old 04-05-2008, 08:41 PM
tobyaxis's Avatar
Moderator
Originally Posted by moldmker View Post
It can be done.
4 mb file size.
Good luck
Using Alibre or BobCAD?
Toby D.
Schwarzwald
Old 04-05-2008, 09:17 PM
Bobcad v21.
I noticed that I missed a couple steps to make solid completely watertight.
I should have done a Boolean function to form the base of the knurl point to a cylindrical surface. Then it would match better when arrayed.
Bob
How to Properly Knurl this Part Crashmaster General Metalwork Discussion 26 06-11-2007 03:23 PM
got bored today Quick change knurl Rainman229 Mini Lathe 8 11-29-2005 01:12 AM
DXF to any SOLID dannyboysd89 General CAM Discussion 11 11-18-2005 06:27 PM
knurl larry53 General Metalwork Discussion 5 11-13-2005 10:08 PM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 07:25 AM
