| BobCad-Cam Discuss all BobCad software here. |
| wont planar I created a wire frame and it wont planer i have been trying to figure it out for two days now and its beyond me I called bob cad support on demand friday but they never got back to me until i called them again today monday so i thought i would look here for help |
| It looks like a bad chain. John |
| the problem is with the geometry. There are overlaps where the radius meets the angled lines of the protrusion in the bottom right hand corner. If you clean them up and redraw the radius it works fine. I have attached the part file. Regards |
| thanks the one is great i knew their was a problem somewhere but i dont understand how it happend i used point conect to join lines and fillet to make the curves and i searched for the mistake zoomed in as much as i could and can never find it is their an easy way to locate something like that |
| I like to use the Chain Select method to find these errors. Just enter into selection mode. Holding the Shift Key down click on an entity. If the entire chain selects, de-select it and try another entity. If there are any overlaps or gaps you should be able to find them using this method. Regards |
| program wont run | laamar | Bridgeport and Hardinge Mills | 8 | 02-27-2008 02:39 PM |
| Using scallop to control stepover doesn't appear to be working with 3D/Planar | surfcam_ken | Surfcam | 11 | 06-01-2007 11:03 AM |
| extrude from planar curve | smoker | Rhino 3D | 3 | 03-21-2007 06:50 PM |
| Why wont this work????? | epineh | General Electronics Discussion | 7 | 03-18-2007 01:44 AM |
| V20 Changing Planar Tool Path | roys29 | BobCad-Cam | 1 | 11-22-2005 12:47 PM |
