Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-16-2008, 10:23 PM
TZ250 is on a distinguished road
3D Area Clear
How would I clear the inside of an area? I'm talking about machining, say, inside of letters or images. (not just on the edge of the letter)
Some programs may call this 'area clear'.
Rob in Ohio
Old 02-18-2008, 04:42 PM
The One is on a distinguished road
I would suggest starting with a Z-Level Rough. Then, as long as you are using the part in the image, you can use the Z-Level Finish to finish it up.
Regards
Old 02-18-2008, 09:27 PM
Will Z level rough cut one area (letter) at a time? I'd like to finish one letter before moving to another one.
Rob in Ohio
Old 02-19-2008, 08:07 AM
If you select the "By Area" option the system will complete one feature of the part before moving to the next.
In cases such as the perimeter of the letters, if you are making the letters an embossment on the part, the system will create path to complete the perimeter before moving to the inside of the letters.
Regards
Old 02-19-2008, 11:29 AM
ErnieD is on a distinguished road
3D area clear
Rob,
I do not know if this will help but go to www.cadcamtrainer.com and watch Sorin's videos.
ErnieD
Help with clear finish trooper55 WoodWorking 11 03-05-2009 07:35 PM
sl20 alarm 144 help need to clear mkmk123 Haas Lathes 1 11-23-2007 12:48 PM
How do I clear my cookies? CNCadmin CNCzone.com FAQ 0 10-22-2007 03:33 PM
Optically Clear Adhesive ejlouis Laser Engraving & Cutting Machines 0 07-24-2007 05:05 PM
How do you clear variables after the prg. is done?? theemudracer Fanuc 18 03-25-2007 10:21 PM
