Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-16-2008, 10:20 PM
BIGRAGU is on a distinguished road
Advice on scanner to plasma PLEASE
Hello all,
I haven't been on for a while but I have just ran into a problem. I recently purchased a C&G Systems Plasma/Torch table with a Burny 1250+ controller. I am using Fastcam software with Fastnest. I have the desktop linked to the table with RS232. I also have the ability to transfer the program on a floppy disc. I have been doing fine drawing with the fastcam for any geometric shapes that I need to cut but now I need to be able to scan a picture or part and get it turned into a DXF file.
I do have Bobcad V21 with Bobnest v3.0 and BobART PRO-X. I have had it for a while but I haven't done anything with it. It does have a post processor library that lists the 1250 Burny.
I also have Corel Draw X3. This is also a program that I have had for some time and have done nothing with. I also have purchased Sheetcam and Mach3 although I don't have any idea where they are so I am sure I will have to buy them over. I purchased all of this about 2-1/2 years ago when I started building a plasma table. The table got put on the back burner and everything has just sat still. Now that I have purchased the C&G I really need to get up to speed with this stuff.
I really have no idea what software will be better to use for what I am needing to do or for that matter how to use it. If anyone has any insight or advice it would be greatly appreciated.
Thanks, Chris
Old 02-17-2008, 01:13 PM
P.S.
If there is any other software or equipment out there that will simplify this project, I am interested in any suggestions. I am willing to buy whatever it takes to get this thing going.
Thanks, Chris
Old 02-18-2008, 12:15 PM
tjones's Avatar
tjones is on a distinguished road
Bobart pro does loads for vectorizing it really counts on what you need to do with it. I don't use it here so I can't be of too much help.
Old 02-18-2008, 04:36 PM
The One is on a distinguished road
You should also be able to create the dxf files using Corel. You can then use them in which ever program you are comfortable with.
Regards
4 in 1 Plasma Cutter/TIG Welder, advice please masheenist Welding, Brazing, Soldering, Sealing 21 01-18-2012 09:27 AM
Need CAD software advice. (Plasma) xjer General CAM Discussion 1 09-13-2007 12:20 PM
Advice? CNC Plasma Table bshooter17 CNC Plasma and Waterjet Machines 8 02-07-2007 09:24 AM
Advice for CNC plasma cutter yellow CNC Plasma and Waterjet Machines 3 09-21-2006 02:31 PM
Want to buy 4x8 cnc plasma any advice good or bad Tj,s welding CNC Plasma and Waterjet Machines 13 12-16-2005 07:12 PM
