Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-12-2008, 05:13 PM
TZ250 is on a distinguished road
Dimensioning A Solid
Guys,
How do I dimension a radius on a solid? When I try to dimension a radius, I get about 50 lines from various areas.
I've already deleted the XY drawing that I extruded.
I can't remember what I made a certain radius.
Thanks in advance.
Rob in Ohio
Old 02-13-2008, 08:12 AM
The One is on a distinguished road
You will need to extract the edges of the part to dimensions the radius. The system will currently only dimension between snap locations (edges and mid-points).
Regards
required advise about dimensioning fsa Mechanical Calculations/Engineering Design 3 01-14-2008 04:29 PM
Dimensioning and help files? LorenzoNH TurboCAD/CAM 3 04-27-2007 03:33 PM
dimensioning solids sc_crasher BobCad-Cam 1 03-16-2006 01:56 PM
Auto dimensioning? trubleshtr Autodesk Software (Autocad, Inventor etc) 1 03-24-2005 06:05 PM
Dimensioning? Ken_Shea OneCNC 4 07-09-2003 09:51 AM
