Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-07-2008, 09:58 PM
mmachining is on a distinguished road
I and J 3D arcs
Like some help please. I am trying to make a part that I want to mill a radi in the X and Z plane using I and J. right now all I get when I generate G code is X,Y, and Z. Anyone got any helpful hints?
Old 02-07-2008, 10:00 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
You need I and K with X,Z.
Stefan Vendin
Old 02-07-2008, 10:02 PM
I see so in X,Y I diable the K factor and in X,Z or Y,Z I enable is that right?
Old 02-07-2008, 11:59 PM
You don't disable or enable anything.Ok,sorta.
Just use the right plane.
XY=G17 Plane IJ
XZ=G18 Plane IK
YZ=G19 Plane JK
With G18 you work in (Enable) the XZ plane.
Stefan Vendin
Old 02-08-2008, 01:00 AM
This program produce a little bowl.
Download and install CNCsimulator an try it.
http://www.cncsimulator.com/
Code:
G40  G80 G49 G18 G21
G0  G90 G54 X0 Y0 T4 S2000 M3
G43  Z100 H4 M8
G1  X0 Y14.8 F500
Z-0.1  F150
G2  X0 Y14.8 I0 J-14.8
G0  Z2
G1  X-14.8 Y0 F150
Z-0.1
G3  X14.8 Y0 I14.8 K0
G0  Z2
G1  X-14.77 Y0.92 F150
Z-0.1
G3  X14.77 Y0.92 I14.77 K0
G0  Z2
G1  X-14.685 Y1.84 F150
Z-0.1
G3  X14.685 Y1.84 I14.685 K0
G0  Z2
G1  X-14.54 Y2.76 F150
Z-0.1
G3  X14.54 Y2.76 I14.54 K0
G0  Z2
G1  X-14.335 Y3.68 F150
Z-0.1
G3  X14.335 Y3.68 I14.335 K0
G0  Z2
G1  X-14.065 Y4.6 F150
Z-0.1
G3  X14.065 Y4.6 I14.065 K0
G0  Z2
G1  X-13.73 Y5.52 F150
Z-0.1
G3  X13.73 Y5.52 I13.73 K0
G0  Z2
G1  X-13.325 Y6.44 F150
Z-0.1
G3  X13.325 Y6.44 I13.325 K0
G0  Z2
G1  X-12.84 Y7.36 F150
Z-0.1
G3  X12.84 Y7.36 I12.84 K0
G0  Z2
G1  X-12.265 Y8.28 F150
Z-0.1
G3  X12.265 Y8.28 I12.265 K0
G0  Z2
G1  X-11.59 Y9.2 F150
Z-0.1
G3  X11.59 Y9.2 I11.59 K0
G0  Z2
G1  X-10.795 Y10.12 F150
Z-0.1
G3  X10.795 Y10.12 I10.795 K0
G0  Z2
G1  X-9.855 Y11.04 F150
Z-0.1
G3  X9.855 Y11.04 I9.855 K0
G0  Z2
G1  X-8.715 Y11.96 F150
Z-0.1
G3  X8.715 Y11.96 I8.715 K0
G0  Z2
G1  X-7.29 Y12.88 F150
Z-0.1
G3  X7.29 Y12.88 I7.29 K0
G0  Z2
G1  X-5.345 Y13.8 F150
Z-0.1
G3  X5.345 Y13.8 I5.345 K0
G0  Z2
G1  X-1.535 Y14.72 F150
Z-0.1
G3  X1.535 Y14.72 I1.535 K0
G0  Z2
G1  X-14.8 Y0 F150
Z-0.1
G0  Z2
G1  X-14.77 Y-0.92 F150
Z-0.1
G3  X14.77 Y-0.92 I14.77 K0
G0  Z2
G1  X-14.685 Y-1.84 F150
Z-0.1
G3  X14.685 Y-1.84 I14.685 K0
G0  Z2
G1  X-14.54 Y-2.76 F150
Z-0.1
G3  X14.54 Y-2.76 I14.54 K0
G0  Z2
G1  X-14.335 Y-3.68 F150
Z-0.1
G3  X14.335 Y-3.68 I14.335 K0
G0  Z2
G1  X-14.065 Y-4.6 F150
Z-0.1
G3  X14.065 Y-4.6 I14.065 K0
G0  Z2
G1  X-13.73 Y-5.52 F150
Z-0.1
G3  X13.73 Y-5.52 I13.73 K0
G0  Z2
G1  X-13.325 Y-6.44 F150
Z-0.1
G3  X13.325 Y-6.44 I13.325 K0
G0  Z2
G1  X-12.84 Y-7.36 F150
Z-0.1
G3  X12.84 Y-7.36 I12.84 K0
G0  Z2
G1  X-12.265 Y-8.28 F150
Z-0.1
G3  X12.265 Y-8.28 I12.265 K0
G0  Z2
G1  X-11.59 Y-9.2 F150
Z-0.1
G3  X11.59 Y-9.2 I11.59 K0
G0  Z2
G1  X-10.795 Y-10.12 F150
Z-0.1
G3  X10.795 Y-10.12 I10.795 K0
G0  Z2
G1  X-9.855 Y-11.04 F150
Z-0.1
G3  X9.855 Y-11.04 I9.855 K0
G0  Z2
G1  X-8.715 Y-11.96 F150
Z-0.1
G3  X8.715 Y-11.96 I8.715 K0
G0  Z2
G1  X-7.29 Y-12.88 F150
Z-0.1
G3  X7.29 Y-12.88 I7.29 K0
G0  Z2
G1  X-5.345 Y-13.8 F150
Z-0.1
G3  X5.345 Y-13.8 I5.345 K0
G0  Z2
G1  X-1.535 Y-14.72 F150
Z-0.1
G3  X1.535 Y-14.72 I1.535 K0
G0  G40 Z50
X0  Y0 M5 M9
M30
Stefan Vendin
Old 02-08-2008, 07:14 PM
Stefan, Thanks for the link. I cant seem to get it to work in inches. If I PM you the code I have would you mind running it for me? When I run it in Bob-cad it is not smooth in the simulation. but it looks good when you just look at the toolpaths.
Old 02-08-2008, 08:13 PM
Go ahead and PM me.
If you want to change the program to inch,just click on "Settings" and login.Password is -login.
When you have done that,click on "Settings" again and then "Simulation settings" and you'll find what you're looking for.
Stefan Vendin
Old 02-14-2008, 02:01 PM
jshinn is on a distinguished road
XY=G17 Plane IJ
XZ=G18 Plane IK
YZ=G19 Plane JK
I also have been trying to cut curves/radi in xz or yz. Where could I change or select the right plane? Do I chose this on the cad or cam side? When I am trying to cut curves in 3d it breaks it down to little lines and jerks the machine when cutting. If you have any ideas let me know please.
3d arcs? stevespo BobCad-Cam 10 08-31-2007 09:02 PM
Huge Arcs HELP ????? Biggermens Mach Software (ArtSoft software) 3 04-26-2007 09:50 AM
Huge Arcs Biggermens Mach Lathe 0 04-23-2007 11:49 AM
Smoothing 3d arcs? stevespo BobCad-Cam 14 04-20-2007 07:46 AM
Points on arcs gguidi Autodesk Software (Autocad, Inventor etc) 2 07-25-2006 08:49 AM
