Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-04-2008, 04:27 PM
LYN BYRD is on a distinguished road
Angry VERIFY
JUST INSTALLED LATEST UPDATE (BUILD 861) AND NOW THE VERIFY WITHIN BCAD QUIT WORKING. ANY IDEAS?
THANKS
Old 02-04-2008, 05:09 PM
The One is on a distinguished road
It may have been one of several things, so I am going to give you multiple options, starting with the easiest first and most deytailed last:
1) In the case that it just an OCX registration issue:
Open the NC Verify folder under your BobCAD-CAM V22 (C:\Program Files\BobCAD-CAM\BobCAD-CAM V22\NC Verify\)
Then double click on the reg_ocx.bat file (This will open a command window and registers the needed files for the system), click OK through the four dialogs that appear in the foreground.
2) In the case that the license option got modified:
Open the Predator Virtual CNC 7.0 folder (C:\Program Files\Predator Software\Virtual CNC 7.0\)
In here you will find a file called VirtualLicensingMgr.exe, double click on this file to open a dialog.
In the Select License field select Predator Virtual CNC for BobCAD and then click OK.
3) In the case that neither of the above work:
Uninstall the Predator Virtual CNC system from your computer.
Open the System Files folder under BobCAD V22 (C:\Program Files\BobCAD-CAM\BobCAD-CAM V22\System Files\)
Locate and double click on the Predator Virtual CNC for BobCAD.msi file. This will install a fresh instance of Predator on your computer. If you can not find the msi file, you can download it from the BobCAD site: http://s229444871.onlinehome.us/bobc...r%20BobCAD.msi
Hope this helps.
Regards
Old 02-05-2008, 08:07 AM
system folder and contents was missing
thanks
Old 02-06-2008, 07:59 AM
Did that help fix the issue?
Regards
Old 02-06-2008, 08:49 AM
yes, the verify works now.
thanks for your help
Old 02-06-2008, 09:00 AM
Good! Glad I could help.
Regards
Old 02-12-2008, 01:48 PM
PinMan's Avatar
PinMan is on a distinguished road
Talking
I was having the very same problem with verify. I found this post and now my verify is working just fine.
Thank you guys
Please verify my code Hack General CAM Discussion 6 11-05-2007 07:41 PM
HELP! Rotating an STL file generated in verify AMCTony Mastercam 7 07-24-2006 09:25 AM
Please verify my Driver Wires electron Stepper Motors and Drives 1 02-22-2006 10:54 PM
4 axis verify utility? DAB_Design General CNC (Mill and Lathe) Control Software (NC) 6 04-27-2005 01:38 AM
Gcode verify autocad plugin balsaman General CAM Discussion 1 10-31-2003 12:22 PM
