Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-24-2008, 09:17 PM
brockadeau is on a distinguished road
3D wireframe creation
Hello-- I have all the versions of Bobcad from 12 Gold all the way up to 2007. I still can't seem to be able to create a 3d wireframe similar to the attachment. Could someone please help. If a wireframe is not scaleable I need it to be 21" across the diagonal. thaks in advance- Jack
Old 01-25-2008, 07:18 AM
tjones's Avatar
tjones is on a distinguished road
Create it as a solid using the basic solids menu and the boolean feratures. From the small icon it is hard to tell what the form is really like but it looks pretty simple.
Old 01-25-2008, 08:42 AM
pattern
Tjones-- thaks for the reply. The surface is basically a series of raised dimples connected by a smooth wave and then cut into a rectangle at the center of 4 of the dimples (leaving one full dimple in the center). Any chance you could create this for me (or better yet explain in a little more detail the steps involved). I would like the diagonal to be 21 inches and a difference of about 2 inches from the top of the dimple to the bottom of the trough, and then get it to be machineable. I purchased the v22 tutorial cd"s, but still can't figure it out. I'm old school and barely get by in 2D-I also have version 21 ith Bobartpro if that helps- My version 2007 is only 2D. thanks-- Jack
Old 01-25-2008, 09:10 AM
tjones's Avatar
I can get you started easy enough but I am not sure how you plan to machine. This appears to need 3D cutting so are you going to use V21?
If so I would be able to help in 21. If you prefer to see the part as you dreate it then V22 is much better on the cad part. However I do not know if you can create solid on your V22. Check to see if you have the Solids>Cube menu available. If so open it and then just click the OK to see if you get a cube.
Old 01-25-2008, 10:08 AM
bobcad
I probably would rather use v 21 as I am somewhat familiar with that-- haven't had much oportunity to learn v22-- Jack
Old 01-25-2008, 10:09 AM
I would rather use v 21
Old 01-25-2008, 11:00 AM
tjones's Avatar
Step 1:
Go to menu Solids>Primitives
Select CUBE then click Ok.
Select MIDDLE
Enter X 0, Y 0, Z -2 in the top menu
Enter X 21,Y 21, Z 4 in the bottom menu
Click the USC Icon in the upper right corner and select Default for the view
Press the Z key to zoom to the part extents
Now you should see the wire frame of the base block (don't worry about the thickness as it does not really matter for machining the part top.)
I will be back in a while for the solids>shpere.
I have to work and only doing this during breaks.
Old 01-25-2008, 01:54 PM
tjones's Avatar
I went ahead and created this but will have to wait to give instructions.
Not knowing the size of radii it makes it harder to produce what you want.
Bobcad is not parametric so making changes is more difficult. This is why I do most of my designing in Alibre.
Old 01-26-2008, 07:16 AM
thanks
Sorry I didn't get back to you yesterday, but things were hectic. Is it possible to have the depression be curved down instead of flat so it's more of a continuous wave? Still with the total difference in height being about 1.5-2 inches. that might male it more of a parabolic curve than a true radius (if i have my terminology correct) connecting the peaks and troughs. like a series of dimpled waves. I will try the first steps you gave me to see what I come up with-- THANKS-- Jack
Old 01-26-2008, 07:38 AM
Tjones-- I can creat the cube, and i think I can add the spheres at the corners and in the middle, but hen I'm lost as to how to create the surface and then crate the toolpath to machine it. (And also how to depress the troughs with a flattened curve.)-- Jack
  #11   Ban this user!
Old 01-26-2008, 08:05 AM
tjones's Avatar
Ok to add the radii at the bottom simply use the Fillet command but first you must combine the sphere and the cube by using the Boolean add.
Do this by simply selecting the cube and one of the spheres then go to Solid>Boolean and select the add.
Do this until all spheres are added to the cube.
Put a very large fillet so the dimply connect smoothly.
So from there you can create 2 squares (one to match your outside solid form and the other much bigger to clear everything) using these squares we will create a surface and then a solid. (This is to trim the outside by using a bollean subtract.)
  #12   Ban this user!
Old 01-26-2008, 08:44 AM
tjones's Avatar
To create a solid from the 2 squares simply select the two squares and go to Solids>Surface Creation>Planer and click next.
The order the 2 squares are selected determine how Bobcad creates the hollow box we are going to create.
Once you get the correct form then we need to select the plane and go to Solids>Surface Creation>Extrude Surface. Enter a large enough distance to cover you entire form depth in Z and make sure the Caps is checked.
Now you can do the Boolean subtract like the Boolean add (the order of selection determines the piece to remain).
Sorry I am doing this off the top of my head and in a hurry so I I left out soemthing just ask.
Tags
3d wireframe, basic solids
2D Wireframe Error ramasule Mastercam 16 01-16-2008 07:50 PM
Surface Creation Help stevespo BobCad-Cam 3 05-17-2007 05:55 PM
Solid to wireframe HELP Clawsie Machine Mastercam 3 05-22-2006 11:10 AM
3D Wireframe to 3D Solid. How is this done? Beezer Autodesk Software (Autocad, Inventor etc) 4 07-22-2005 11:15 PM
3D wireframe surface JW Peters Autodesk Software (Autocad, Inventor etc) 3 05-09-2005 08:23 PM
