Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
  #13   Ban this user!
Old 01-26-2008, 11:32 AM
brockadeau is on a distinguished road
T-- I have the rectangle with the 5 spheres, but I can't seen to fillet them
  #14   Ban this user!
Old 01-26-2008, 11:33 AM
And I'm trying in v 22
  #15   Ban this user!
Old 01-27-2008, 06:36 AM
tjones's Avatar
tjones is on a distinguished road
You must first Boolean add them to make them a single solid
  #16   Ban this user!
Old 01-28-2008, 06:14 AM
thanks
Tjones-- I got it! Only problem is I think I must have drawn it in mm at home, because it is less than an inch long when imported at work, but it's not that hard to draw once you understand booleen a little. Thanks to your expert tutoring. Now I have a more simple question. I need to curve the face of the attached cabinet to the curve of the side view (i rotated the side view in the y axis). I need to cut out the rectangles along the curved face after the wood is bent-- thanks in advance-Jack
  #17   Ban this user!
Old 01-28-2008, 06:27 AM
3d
Here's the 3d item I created
  #18   Ban this user!
Old 01-28-2008, 07:29 AM
tjones's Avatar
First....you can scale your part by using the same translate feature. It has a scale that you can check and enter a 25.4 scale to get it up to size if needed.
Next....The easiest way is to create a solid from the contour section. Do this just like the box. Solids>Surface Creation>Planer Surface. Then Solids>Surface Creation> Extrude Surface. Create a solid that is large enough to cover the entire 2Dform.
Next you will use a nice feature of Bobcad.
Select the form and then go to menu Solid>Project curve to surface. Then you select the solid you just created and it will project the form to the curve.
  #19   Ban this user!
Old 01-31-2008, 08:11 PM
I tried
tjones-- here is the dxf file of what I tried. It says it failed the attempt-- Jack
  #20   Ban this user!
Old 01-31-2008, 08:42 PM
tjones's Avatar
Try re-drawing the form. For some reason it will not allow me to do it either. At least not in V20...maybe V22 would....will try it.
Tags
3d wireframe, basic solids
2D Wireframe Error ramasule Mastercam 16 01-16-2008 06:50 PM
Surface Creation Help stevespo BobCad-Cam 3 05-17-2007 04:55 PM
Solid to wireframe HELP Clawsie Machine Mastercam 3 05-22-2006 10:10 AM
3D Wireframe to 3D Solid. How is this done? Beezer Autodesk Software (Autocad, Inventor etc) 4 07-22-2005 10:15 PM
3D wireframe surface JW Peters Autodesk Software (Autocad, Inventor etc) 3 05-09-2005 07:23 PM
