Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-23-2008, 08:37 PM
jmcglynn is on a distinguished road
crashware
OK, I'm pretty new to CAM software - although I've been using SolidWorks for a couple of years and I'm very comfortable with it.
I bought V22 Pro.
First observation: it crashes all the time. Not a good sign.
Second observation: The UI is very awkward, at least compared to SolidWorks and Alibre.
Third: I don't trust the toolpaths it's generating. On Z-axis rough I asked it to ignore the holes, but it still plunges into them. On Z-axis finish the toolpath appears to overshoot the depth. I've re-done the settings several different ways and it still does the same thing. One time when I generated toolpaths it has paths cutting through the sides of the part, when I re-generated without any changes they went away. That's not right.
Fourth: I've atttempted to contact support through the website. Four times in as many days. No response. I'll try the phone, but I'm not optimistic.
Fifth: The FAQ on their website suggests updating the version of BC with a newer build. I did, and now preview doesn't work at all. Just a blank window that says "loading".
I'm not impressed, a CAM package that crashes all the time and generates incorrect toolpaths at random times isn't worth anything IMO.
I hope I'm wrong and that this turns around, but if not I'll be asking them for a refund real soon now.
Old 01-24-2008, 03:40 AM
Khalid's Avatar
Khalid is on a distinguished road
Ohh.. Many viruses dont like BOBcad Cam...
Pls check ur harddrive with reputable anti virus program
Old 01-24-2008, 07:18 AM
tjones's Avatar
tjones is on a distinguished road
As for Z axis rough and finish. Please check the endmill type. If the tool has a radius on the corner then it will need to go beyond the side depth to get the entire form to clean up. (past the corner radius of the tool)
You can limit this in 3D cuts by placing a false, solid face, bottom to force Bobcad to stop the cut in Z.
I am not seeing the cuts like you describe going into the surfaces. There is situations in pocketing where you can place a start point to make it cut through an island (been trying to get this one fixed for some time). This requires moving the start point to the other side of the island as a work around.
Old 01-24-2008, 02:38 PM
On the crashing they told me this was because auto save wasn't turned on. I checked this with the tech support rep on the phone, and it was turned on (set at 5 minute intervals). Then he said it might not be auto saving (even though it was turned on), we checked and it is in fact auto saving to the backup directory. Then he told me to manually save my file every few minutes. This isn't acceptable, my interpretation of this is "we expect it to crash every few minutes so save your work constantly"
Disappointing, I really want to like this software but it's not cooperating...
Old 01-24-2008, 02:52 PM
No radius, both are square endmills (3/8" rough, 1/4" finish to get into the small radius)
The islands in this example are a result of overshoot I believe, not isolating. There isn't a "start point" setting for Z-Axis rough or finish that I see.
I'll post a pic with a screenshot...
Old 01-24-2008, 02:54 PM
I'm attaching two screen shots of the verify operation for the "overshoot" problem.
As you can see in the "during" picture, the z-axis finish is only tracing the periphery of the pocket. The z-axis rough was set at .030" allowance (I get the same results with no allowance set). It continues to trace the perimeter of the pocket, overshooting the bottom of the pocket by about 1/8" (this part is 3" OD, so I'm guessing the overshoot visually).
Both rough and finish have the top of part set the same.
ID:	51580   Click image for larger version
Old 01-24-2008, 07:52 PM
tjones's Avatar
Change the color of your rough and finish passes to more easily see where this is occuring. I have yet to get anything like this where I did not have something set incorrectly.
But I would like to repoduce this error so I can report it.
Old 01-24-2008, 09:20 PM
spock is on a distinguished road
My experience has been the same, when I get unplanned results it has turned out to be the settings. I agree that the UI is a little weird, when filling in some info in machining operations some stuff doesnt seem to make sense.
What I have started doing is to check surface normals on 3-d models before I ever start programming. And I use large stepovers/depths until I get the path correct, then go back and set it where I want it, saves me time. But I am getting better, I am getting alot of use out of the 3-d paths now, after alot of practice I am usually getting it right on the fisrt couple trys.
Old 01-24-2008, 11:16 PM
I'm working on a more complex part now, and it's actually going much smoother. Fingers crossed. The first part I tried is so simple that it just didn't make sense that I'd have so many problems, and honestly tech support wasn't helpful.
Question: on z-axis rough how can I stop it at some waterline? Do I have to fake it out by adding a horizontal solid?
Old 01-25-2008, 07:14 AM
tjones's Avatar
That may be one way but there is another. This one may sound strange as it does not allow for for multiple boundries.
The 'Stock Geometry' located under the 'Milling Stock' is used for a boundry in Z level machining. When set to machine all then it will machine the entire stock defined by the Stock Geometry and ignore any solid area outside of the stock geometry even if selected.
  #11   Ban this user!
Old 01-31-2008, 10:35 AM
Thanks for the idea, but that doesn't work. I set the stock up as a 1" thick block covering just the area I need to machine to put the rest of it into a fixture. As you can see the z-axis toolpaths completely ignore it.
I'm so frustrated with this software, nothing seems to work properly. Their tech support has been completely unresponsive.
I'm going to look into a refund I think.
  #12   Ban this user!
Old 01-31-2008, 06:26 PM
tjones's Avatar
This is not a boundry issue this is a Z level machining function.
Boundry sets X-Y.
Try adding a simple plane (solid surface) that extends beyound the boundry to limit the Z axis depth.
Basically the surface would be like your fixture so it knows where it needs to stop.
