Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-22-2008, 05:48 PM
jmcglynn is on a distinguished road
BobCad 22 Newbie
I just bought and installed BobCad 22, the pro version with Z-axis routines.
The first issue I've run into is that I can't use 2D operations or drill operations on 3D parts. This doesn't make any sense... For example, I have a simple 3D part I designed in SolidWorks and imported (I've had this same behavior importing parts as .sldprt and .step).
If I add a drill operation I can't select the hole geometry. I tried making it a contour, but the contour command doesn't succeed (no error, it just fails silently).
So the only option is to lay out 2D geometry to select it for the holes -- not good.
Also, on the Z-Axis rough and finish operations, even if I tell it to "ignore holes" it plunges into the three screw holes in this part...
Anyone have some guidance here? Is this just buggy software? (it crashes fairly often, I have a fast CPU and 4GB of ram)
Joe
Old 01-22-2008, 08:22 PM
*Registered*
COMMAND JOHN is on a distinguished road
Go to utilites >> and extract edges and you can select holes.
In 3D select outer most only.
And yes it is buggy in some 2D.
Old 01-23-2008, 12:06 AM
tjones's Avatar
tjones is on a distinguished road
You can also use the project to surface using a plane after extracting the edges. Then cleanup and optimize and erase doubles.
BobCAD to Solidworks (For sale BobCAD) Robert Lewis BobCad-Cam 3 05-11-2009 05:04 AM
BobCad offer to end all Bobcad Offers Syil_Australia Product Announcements & Manufacturer News 0 02-01-2007 06:07 PM
Would you recommend Bobcad/cam to a newbie? Legion99999 BobCad-Cam 8 01-06-2007 11:12 AM
Newbie Help!! Mach2/3-Bobcad Problems bcromwell General CAM Discussion 5 06-28-2005 09:20 AM
