Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-17-2008, 02:33 PM
Gunner75 is on a distinguished road
Tree 425 with PC2100 controller and BOBCAD
Anyone have any experience with Bobcad and the PC2100 controller?
Trying to drill holes and keep getting a Peck Drill Flag.
FYI, I am a newcomer to the machining world. If you couldn't tell.
Peck Drill
> No feed increments for G83 deep hole drill.
> Cause: The G83 deep hole drill cycle requires a non zero value to use the
> feed increment. It looks in the following places in the order indicated,
> and uses whichever it finds first.
> 1 K word programmed in the G83 block.
> 2 Cycle modal set by execution of previous G83 block.
> 3 Compensated diameter of the active tool, which is the sum of two values
> from the tool data table and diameter compensation selected by programmable
> tool offsets.
Tree-Siemens Acramatic controller question The_Roadrunner Tree 8 09-09-2011 12:14 PM
Tree 425 with PC2100 controller and BOBCAD Gunner75 Tree 1 01-17-2008 11:53 PM
tree journeyman 250 mill with anilam pc2100 mjr8 Tree 0 05-20-2007 08:34 PM
tree 220 with centurian v controller tractorguy Tree 0 12-07-2006 04:00 PM
BobCad with WinCNC controller 2.1 Scott V BobCad-Cam 9 01-17-2006 02:23 PM
