Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-15-2008, 12:58 PM
reedmiles is on a distinguished road
3-D TOOL PATH
I AM HAVING PROBLEMS WITH 3-D, 2-D WORKS FINE TOOL PATH WHEN I TRY I GET A ACCESS DENIED POP UP I WENT TO THE WEB SITE AND IT SAID TO TRY AND UPDATE THE LICENSES WHICH I DID STILL NO LUCK I THEN UPDATED THE PROGRAM, V-22 BY THE WAY. STILL NO LUCK I CALLED TECH SUPPORT THEY SENT ME A E-MAIL WITH AN UPDATE FOR THE LICENSES BUT EVERY TIME I TRIED TO UPGRADE IT KILLED THE PROGRAM, I THEN DID A SYSTEM RESTORE BACK TO BEFORE I UPDATED V-22 AND WENT BACK TO THE WEB SITE AND DOWNLOADED THE UPDATE FOR V-22 AND SAVED IT TO DESKTOP AND LOADED IT FROM THIER SAME RESULT I HAVE TRIED TO CONTACT TECH SUPPORT BUT THEY ARE APPARENTLY SWAMPED WITH CALLS HAS ANYONE HAD THE SAME PROBLEM THANKS
Old 01-15-2008, 02:26 PM
tjones's Avatar
tjones is on a distinguished road
Try turning off your firewall and antivirus and then run the update.
Old 01-15-2008, 02:41 PM
Randy Stevenson is on a distinguished road
I had the same problem. As soon as I installed the latest update, trying to generate 3D toolpath would return the "access denied" error. It was Friday night, and I figured I was sunk, as I needed it over the weekend. But, I learn that tech support is in from 10 to 2 on Saturday. Called in and got right through to a tech. He said he would e-mail instructions to fix. Got the wrong file (predator info), called back and had to leave a message. Second e-mail arrived quickly but did not solve the issue (told me to try and update my license file online, but it wouldn't do it). Had to leave another message, then got a third e-mail with a new license update file which did solve the problem. All of this was done in no more than an hour, so my experience with tech support was good.
All I had to do was choose Update License (from the help menu), select the file just received, and click on Update. I'm running XP, for what it's worth.
Randy
Old 01-15-2008, 05:08 PM
tried turning off firewall and anti virus same results. with the original configration of v-22 now when i try to update from file they sent me, i get a not authorized to update licenses
Old 01-16-2008, 01:30 PM
bobcad called determined it was a bad dongle they are going to send me a new one
Old 01-16-2008, 02:48 PM
whoafat is on a distinguished road
I have purchased a brand new copy of v22 Bobcad cam that comes with a dongle. The above discussions peaked my curiositya and I went to the help menu to see what happens when I try to upgrade licence. The system asked for a new licence which I do not have; why? My question is. Given that I have a recent copy of Bobcad cam v22 with the dongle, why would I need a new upgrade licence?
Old 01-16-2008, 03:03 PM
The One is on a distinguished road
whoafat,
The upgrade license option is used in two cases:
1. You purchase additional modules that need to be registered.
2. An update in the software requires that additional information be added to the dongle.
The Dongle should be in the computer when you choose to update the license. The update online button retrieves the updated file automatically. If for some reason the server is incapable of creating the proper file, BobCAD support will send you the necessary file and you will use the update option.
Regards
Old 01-16-2008, 03:14 PM
thansk,
Wilfred
Old 01-28-2008, 08:48 AM
I recived my new dongle friday it it allowed me to create 3-d tool path once, it asked to allow access to Bobcad which I allowed, I assumed that they needed to verify the dongle. Now it will no longer create 3-d tool path. What is intresting is that I tried to use it on my 2007 version, and it works fine, go figure
RMILES
Old 01-28-2008, 12:42 PM
tjones's Avatar
The dongle only works on the 2007. It does not effect any other versions. Or is the V22 that you are reffering to? V22 is 2007 but with certain internal changes.
  #11   Ban this user!
Old 01-28-2008, 03:16 PM
the dongle works fine on the 2007 version that i have not upgraded, but will not work on the upgraded 2007 (ver 22)
RMILES
  #12   Ban this user!
Old 01-29-2008, 02:00 PM
tjones's Avatar
Now I understand. So it must be a dongle update required. I did mine and did not loose any of the options I had.
Tool Path cijunet Mastercam 9 11-26-2007 10:17 AM
Tool approach Tool Path Kiwi BobCad-Cam 28 07-05-2007 03:35 AM
efficient tool path balsaman Mastercam 32 07-28-2006 12:37 PM
getting tool path problem kenlambert BobCad-Cam 0 01-14-2005 03:15 PM
Tool Path WOODKNACK TurboCAD/CAM 4 06-27-2003 08:27 AM
