Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-15-2008, 08:15 AM
keen is on a distinguished road
Probing/Digitizing into BCC?
Hi All - I have jumped across into this forum to see if anyone can give me the latest info on V21's ability to receive files ex Probing/Digitizing. specifically I have a Tormach mill which is controlled by Mach3 - and I use BCC v21.
I would like to buy a (hopefully not too expensive) digitizing probe and learn how to reverse eng 3D parts - Tormach and Mach 3 seems to be well set up to do this? - But my main question is: Once the part has been digitised and the 'point cloud' file is made - can it be imported into V21 in some form so it can be converted into a solid or surface (and then modified, repaired etc) - or is this too big an ask for V21? - is anyone out there doing this?
Thanks for any help!
Still keen
Old 01-17-2008, 06:45 PM
smurph is on a distinguished road
This is typically done in specialized "meshing" software. It takes the point cloud information and user input to transform the point cloud into something more palatable for the CAD/CAM software.
To this end, one of the Mach digitizing plug-in guys is also working on a meshing program.
Steve
Old 01-17-2008, 07:40 PM
Thumbs up
Thanks Steve
Do you or does anyone know of a good affordable 'meshing software' package out there - i will google it but any info welcome!
still Keen
Old 01-17-2008, 08:09 PM
Yeah, google on this search "point cloud meshing". The first three are about the most affordable. The first two, Point Cloud and Points-to-Polys have a demo that you can try out. I have loaded both of these. The third, VRMesh, I don't know if the have a demo. But it looks to be quite capable. It's also more expensive.
I'd wait until you actually have a point cloud to try out before installing any of them.
Steve
Old 01-17-2008, 09:03 PM
ger21's Avatar
Originally Posted by keen View Post
Thanks Steve
still Keen
Try MachCloud. It's free.
http://www.machsupport.com/artsoft/d.../downloads.htm
Old 01-18-2008, 09:28 PM
Thanks Gerry - looking now!
Old 01-18-2008, 10:00 PM
OK - so i downloaded and unzipped machcloud, found a sample "hand" point cloud file - found the tool to flesh it out - and found it could only be saved as STL. BCC does not import STL. But on googling STL coversion software - seems i have many options!
Any comments welcome!
Still Keen
Old 02-01-2008, 01:16 AM
racefast is on a distinguished road
if you need i can provide you a point cloud i have a centroid equipped mill with full digitizing capabilities I am running v22 and i would be interested in doing the same thing you are wanting to do so if you could give me some feedback on your findings i would be happy to give you a point cloud file but it is in a dig file format
Old 02-01-2008, 09:16 AM
The One is on a distinguished road
Keen,
BobCAD will import STL files, and I suggest the Binary format. If you look at the STL created by MachCloud in Notepad you will see that it is ASCII format.
Regards
Old 02-02-2008, 08:13 PM
tjones's Avatar
tjones is on a distinguished road
There is an easy way to do this. Bobcad does open the binary STL files but Machcloud only exports ascii.
So use another program to cleanup and convert to a stl format Bobcad likes.
http://meshlab.sourceforge.net/
It's free source so have fun.
  #11   Ban this user!
Old 02-03-2008, 05:15 PM
Thanks - I will get back to you if i need that - cheers
  #12   Ban this user!
Old 02-03-2008, 05:18 PM
Originally Posted by The One View Post
Keen,
Regards
Thanks - tell me - where in V21 is the opening files in STL? If i look in the drop down from 'files of type' - i don't see STL - or any mention of STL in my V21 manual. Does it go also by another name? keen.
Renishaw probing -- NON VQC gromit68 Haas Mills 5 01-19-2008 10:34 PM
Which Probing System? jimgarner Haas Mills 7 10-30-2007 09:17 PM
Mach and probing KKutt Mach Mill 2 04-22-2007 01:05 PM
probing option Vern Smith Haas Mills 9 02-24-2007 08:49 PM
Probing geverhart WoodWorking 1 09-03-2004 03:41 PM
