Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
  #13   Ban this user!
Old 02-03-2008, 04:25 PM
keen is on a distinguished road
Originally Posted by tjones View Post
There is an easy way to do this. Bobcad does open the binary STL files but Machcloud only exports ascii.
So use another program to cleanup and convert to a stl format Bobcad likes.
http://meshlab.sourceforge.net/
It's free source so have fun.
Thanks - I copy below - which format would you import and export? Cheers
"painting interface for selecting, smoothing and coloring meshes.
Input/output in many formats:
import:PLY, STL, OFF, OBJ, 3DS, COLLADA, PTX
export:PLY, STL, OFF, OBJ, 3DS, COLLADA, VRML, DXF
Point Clouds support. Now 3D files that are composed only by points are well supported in PLY and OBJ format.
U3D support; MeshLab is the first open source tool to provide direct conversion of 3D meshes into the U3D format. Now you can create pdf, like this with 3D objects with just MeshLab and LaTeX. [/B][/I]"
  #14   Ban this user!
Old 02-04-2008, 06:54 AM
The One is on a distinguished road
keen,
Sorry, V21 does not import STL files. It is V22 only that supports this import type.
Regards
  #15   Ban this user!
Old 02-05-2008, 11:42 AM
tjones's Avatar
tjones is on a distinguished road
Sorry....been answering so many V22 questions I didn't notice this was a V21.
Renishaw probing -- NON VQC gromit68 Haas Mills 5 01-19-2008 09:34 PM
Which Probing System? jimgarner Haas Mills 7 10-30-2007 08:17 PM
Mach and probing KKutt Mach Mill 2 04-22-2007 12:05 PM
probing option Vern Smith Haas Mills 9 02-24-2007 07:49 PM
Probing geverhart WoodWorking 1 09-03-2004 02:41 PM
