| BobCad-Cam Discuss all BobCad software here. |
| I don't think you can have G00 and G28 on the same line.
| H Stephen, For starters, you have used an 'o' instead of a zero '0'. Then you have called a G0 but have not provided any X,Y or Z coordinate following this. Try something like this instead: N2 G91 N3 G0 Z0 N4 G0 X0 Y0 I am not sure what you want to do with the G28 and G91. Hope this helps, Greg www.cncdirect.co.za |
| Hi Stephen, I can't explain why Bobcad would do this. Use DeskCNC for making your code? Cheers, Greg www.cncdirect.co.za |
| G00 or G0 is only used to direct an axis at a predetermined feed rate in the Desk CNC controller. G91 directs the controller to operate in incremental mode as opposed to absolute mode (G90 ) G28 is a soft command to "home" The lines should read : N10 G90 G28 N11 G00 Z0 N12 G00 X0 Y0 you can elininate line 11 if the controller is set to home ZXY ( machine tab, set up) Desk CNC uses IS0 001 as the code driver, your NC out put (cam) should have several options that you select as the Code Driver.ISO 001 is one of the most popular. Use the post processor capability for your M codes and other instructions . Desk CNC will not accept the letter "o" for zero "0". Adobe Machine (old as dirt) |
| Thank you to everyone for their help. I would still like to see if anyone might be able to help me with bobcad. It wrote the gcode like this and i would like it if i could get bobcad to write it write for my controller but i dont know how. Also i miss typed "goo" it should have been "g00" Thanks |
| Problem with Fadal post | MojosMachine | Post Processor Files | 1 | 06-19-2007 08:33 PM |
| DeskCNC Toolpath problem | epineh | General Topics | 3 | 12-19-2006 03:38 AM |
| post problem | foamovercast | General Metalwork Discussion | 0 | 10-17-2005 10:27 PM |
| Post Processor for Deskcnc | CNCadmin | Screen Layouts, Post Processors & Misc | 0 | 02-28-2005 09:47 AM |
| Start up problem deskcnc | CNCadmin | Carken Products (Deskam, DeskCNC etc) | 5 | 05-06-2004 11:00 PM |
