Results 1 to 12 of 12
Thread: V22 posting problem
    Dec 2005
    us
    V22 posting problem
    So far I have been able to get the software to create the toolpath but everytime I try to get it to post the code nothing happens. I downloaded the post I need off the BobCAD website and it appears to be working in that I can see the toolpath around the part profile but when I click on CAM Part like the manual says I don't get the next drop down box that contains the options "Compute All Toolpath; Post; Post and Save etc. I have been right clicking on "Profile" and then "compute toolpath", but when I try to use "Post code" under that drop down I get nothing there. I must be missing something.
    Joe
    Aug 2003
    Joe,
    Make sure that the Feature does not have a read X on it. This means it is set to No Post.
    Then Right Click on the Milling Tools option, this will produce the pop-up menu.
    You should then be able to select the Post or Post and Save As option.
    If this doesn't help call support, because a dialog that doesn't appear does not fall under SOD terms. It is an error that needs evaluation and resolution.
    Regards
    Dec 2005
    us
    posting problem
    One,
    Thanks for your reply. I will give a try tomorrow as I am away from my machine for the rest of the afternoon.
    Joe
    Jan 2007
    America
    Joe, I am sorry I didnt get back to you on that question sooner on Sorrins site. I have a machine down and a ton of work pilling up, and have been trying to get things straightened out the last few days.
    Dec 2005
    us
    Ok, after talking with BobCAD (Noel was very helpful) they determined I had a bad installation. I reinstalled the software and now I can post code. Next, question, my Predator comes up grayed out. It says it's loading but it's lying. Nothing ever happens.
    Joe
    Moderator tobyaxis's Avatar
    Jan 2006
    Quote Originally Posted by Joe Miranda View Post
    Joe
    How are you launching Predator, through the Desk Top Icon, Module, or Verify from the CAM Tree?
    There was a fix for the Verify in the CAM Tree I believe but can't be 100% sure.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Registered tjones's Avatar
    Oct 2005
    Have you updated from the bobcad web sight?
    Dec 2005
    us
    Tobyaxis,
    I was launching from the CAM Tree. I didn't know there was another way to do it. Is the Desktop Icon the one under "Modules" that says "Virtual CNC"? If it is, it is grayed out on my machine.
    Tjones,
    I have not updated from the BobCAD site. The thought never entered my mind. Does that mean they have some fix for this? If so, why wasn't there a note with the software or some kind of follow up phone call from BobCAD letting their customers know that there is a problem with the software and the steps to correct it? When you are new to something you automatically assume that you are doing something wrong. You don't assume that there is a problem with the software. My two cents.
    Joe
    Aug 2003
    Joe,
    The problem with your predator has to do with the self registration of files in the registry. Call support and let them know that is the issue. If they sound bewildered tell them to ask Chris about it. This error is very uncommon, 1 in maybe 100 have it happen to them. It is just that the files in the NC Verify folder are either missing or did not get registered during the installation.
    Regards
    Dec 2005
    us
    One,
    OK. Thanks. Again, the info from you guys has been invaluable and has saved me a lot of time and from becoming exasperated with the software and asking for my money back.
    Joe
    Oct 2005
    Updates for Bobcad software are located at
    http://www.bobcad.net/updates/
    Jan 2006
    Tobyaxis,
    Tjones,
    Joe
    There is a List of Fixes for the Software here on BOBCAD's Help Forum http://216.117.147.20/bobcadsupport/...ead.php?t=2708
    Toby D.
    Schwarzwald
    1. Posting problem
      By gridley51 in forum Forum Questions or Problems
      Last Post: 11-20-2007, 03:25 AM
    2. Posting problem
      By RotaryNut in forum Forum Questions or Problems
      Last Post: 02-11-2007, 11:19 AM
    3. Mastercam posting problem
      By Redd in forum Mastercam
      Last Post: 02-08-2007, 02:24 PM
    4. Problem posting pictures
      By mccafferty in forum Forum Questions or Problems
      Last Post: 07-15-2004, 10:53 AM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
