Results 1 to 2 of 2
Thread: BobCad-Cam v19 post processor installation
    Jan 2005
    I have just purchased BobCad-Cam v19 (Hobby Pro). Along with the main program CD, I received a CD full of various 'post processors'. I cannot get ANY of the post processors to install. I just want the Mach 2 and 3 post processors but I have randomly tried others and I always get a "can't install file" message. I get the same message when I download the files directly from BobCad's website. I don't think there is a problem with my computer. Any ideas?
    Thanks,
    Greg
    Jan 2005
    I found the cure
    After a little searching I found the cure. This works for v19 too:
    "to correct this open a new file in bobcad (blank drawing window), then goto the file menu and click on environment , then click on the general tab, there you will see scripts folder with a button with ... on it , click on button , this will bring up a browse for folder window , in window make sure that scripts is highlighted under the bobcad v20 folder , then press ok , this will bring you back to the environment , under the line that says scripts folder you will see ncconfig folder, click on button next to it, and in browse for folder window , make sure that NCCONFIG is highlighted under bobcadv20 folder then press ok , then press ok on the environment , and close bobcad . now install post"
  1. BobCAD-CAM v17 post processor help
    By johnmac in forum BobCad-Cam
    Last Post: 10-10-2007, 04:29 PM
  2. bobcad post processor for turbocnc
    By Pbrew1 in forum TurboCNC
    Last Post: 08-01-2006, 03:38 AM
