Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 11-12-2007, 09:50 PM
TZ250 is on a distinguished road
Slicing A Sphere
What is the best way to slice a sphere? (or, what are some of the ways to slice a sphere?)
What I want is a 6" radius part that is 4" thick. Essentially, it will look like a saucer plate that is upside down.
I thought the easiest way would be to draw a sphere, the slice and remove the largest portion. I haven't figured out how to do that yet.
Drawing the radius and using revolve is one method, but I'm trying to learn different ways.
BTW, I'm using V22 with Windows Vista.
TIA.
Rob in Ohio
Old 11-12-2007, 10:46 PM
tjones's Avatar
tjones is on a distinguished road
try using the solids primative parts and a boolean subtract.
Old 11-13-2007, 05:25 AM
TJones, please explain primitive parts. I know about the boolean subtract, but I don't know how to seperate the sphere.
Thanks for your help.
Rob in Ohio
Old 11-13-2007, 09:17 AM
ErnieD is on a distinguished road
Slicing a sphere
Rob,
Here is the way that I would do it. Go to the solids, primitives menu and select the sphere. put in the data for your sphere. Then go back to the solids, primitives menu and select the cube. Put in the data for a cube that will cover all the area that you want to take away from your sphere. Select the sphere and then select the cube and do the Boleean difference.
ErnieD
Old 11-13-2007, 04:46 PM
Thanks Ernie!
I was trying to use a plane.
Rob in Ohio
Old 11-13-2007, 06:18 PM
tjones's Avatar
Thats the way. The primatives tools are very easy to use.
milling a sphere bookwurm99 General Metalwork Discussion 13 12-25-2010 01:38 PM
Turning a sphere bookwurm99 General Metalwork Discussion 21 06-20-2007 04:44 PM
Milling a Sphere? NotDylan G-Code Programing 1 06-12-2007 09:56 PM
Can you rout 3D on a 2 1/2d Machine (slicing)? karbunkle1952 General CAM Discussion 9 04-12-2007 06:50 PM
Grinding a Sphere bookwurm99 General Metalwork Discussion 2 04-03-2007 06:56 PM
