| BobCad-Cam Discuss all BobCad software here. |
Per the attached Bobcad file, I'm trying to use the 3-axis Slice Planar CAM feature to pocket out this item which includes fillets and a center post. (FYI this is pretty close to the example Bobcad gives). The problem is that it seems to only be milling the shape of the pocket - i.e. it's not creating 0.1" passes to remove the material in the pocket, it's just taking it all at once! What am I missing? Please note: JWS First Part.pdf is actually a .bbcd file. If you download it, please rename the extension! Thanks! John
__________________ Tormach PCNC 1100, SprutCAM, Alibre CAD |
| You just forgot to specify a depth per pass. To do this: Edit the Feature. In the Parameters page, click on the Step Down button. This will make the Step Dopwn input field visible. Input the amount you wish to take per pass, then click ok. Then re-Compute the toolpath. Regards |
| The One - thanks! That makes sense. The solution was to right click on "Slice Planar", choose Parameters, and in the "depth options" box, choose "step down" and then I entered 0.1 inches Thanks again.
These will remove material faster and give a better finish.
| Cheers!!!!
| MCA (Machine Created Art) | j m | Machine Created Art | 6 | 08-27-2007 07:44 AM |
| Problem opening a file in Torchmate CAD created in Corel12 | blackhollowmfg | Torchmate | 6 | 03-18-2007 06:11 PM |
| Are all riser blocks created equal....... | jstarnes | Bridgeport and Hardinge Mills | 1 | 02-01-2007 03:27 PM |
| Using hatch to get pocket cutting g-code | rippersoft | TurboCAD/CAM | 12 | 12-08-2005 09:03 AM |
| projecting text onto a boolean created surface | Bigfoot1 | BobCad-Cam | 0 | 03-18-2005 03:25 PM |
